Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Water does not flow, it flows very slowly. even the motor does not work.
  • 377 Answers
You need to use a plumbing snake to clean the drain from the output of the InSinkErator, just as you would clean a sink drain. On the bottom of the InSinkErator there will be a small button that will actually be a circuit breaker. This needs to be re-set by pushing it in. I would also get an appropriate size Allen wrench and insert it into the bottom of the ISE at the center. This will allow you to turn the ISE by hand and perhaps break up any debris that might be in the unit. DO ALL THIS WORK WITH THE UNIT UNPLUGGED!!!
Posted on Aug 30, 2010
Water pipes make rattling sound when water turned off
This is known as water hammer and occurs when the flow of water is suddenly stopped by the shutting off of a tap. It can be silenced by making sure that all pipes are securely mounted --- that taps are changed to the screw down type that reduces the flow slowly and if every thing fails by the installation of an accumulator in the lines that absorbes the flow into a gas filled container hence slowing the flow down slowly. The accumulator is available from most plumbing shops and is a screw in fitting
Oct 04, 2013 | Plumbing
Rinse water does not enter
If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 05, 2012 | Whirlpool Washing Machines
Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
May 03, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Machine fills too slowly and continues to fill in whole cycle
Remove the water filler hoses at the machine and test the flow of each one. If very slow, check the inlet screens on the faucet ends for plugging and make sure the faucets furnish full flow. The hoses themselves can sometimes become restricting of flow--replace them if so. Next, check the inlet solenoids on the machine for proper flow and shutoff when the power to them is stopped. They may or may not be cleanable--replace them if they are trouble. Hope this helps!
Jan 10, 2010 | Admiral AW22 Top Load Washer
Pump worked yesterday but would not shut off. I left pressure in system over night, today pressure gone, when I turn pump on, the motor runs, but no pressure or water pumped.
1.Turn off the power going to the pump.
2.Drain all the water inside the pressure tank.
3.Open the priming port plug of the pump, and fill it
full with water.
4. Put the priming port plug back in place. Close the
flow control valve and start the pump.
5. Slowly open the flow control valve to 1/8 to 1/4
open and see the flow stabilize at 20 psi of the
pressure gauge.
Hope this will help.
Nov 20, 2009 | Plumbing
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Aug 14, 2009 | Refrigerators
Slow ice maker,poor water dispencer flow
If you used a self piercing saddle valve to hook up to the water supply it is probably the source of your problem. These should never be used. You need to install a drill in type which will increase the water flow and probably never clog.
Apr 10, 2009 | GE PSS26SGRSS Stainless Steel Side by Side...
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
WATER IS RUNNING EVEN WHEN IT IS OFF
yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Nov 07, 2007 | Bosch SHU4006 Dishwasher
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
167 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
