Question about Kenmore Dryers
My kenmore superba is not working. Does not turn on. It is plugged in and the outlet works. Push the button...nothing. Please help.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Dryer works but washer won't turn on. Washer worked until a few days ago. No warning or events. Just doesn't respond to switch. I can't find a fuse box on the unit itself.
Hi, Have you tried plugging a lamp into the outlet or plugging this into another outlet/extension cord. Check the receptical to see if it is a ground fault style. If it is, push the reset button on it.
If there is power to the washer, there could be a timer issue. UNPLUG the washer. Remove the 2 screws holding the control panel to the cabinet. Some screws are located in front coerners and some in the back corners.
Once the control panel is loose, locate the wire harness on the timer and try wiggling it to get better connection. Plug the washer back in and see if it starts.
Please let me know if this helps or if I can assist you further.
Vic
Jul 10, 2009 | Kenmore 88752 Top Load Stacked Washer /...
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Kenmore top loading washing machine
check the outlet to make sure that power is getting to the unit. This can easily be done by plugging in a lamp or some small appliance. If you have power at the outlet, it is most likely the lid switch.
The switch is inside the washing machine main housing near the door frame. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. Unless you are familiar with working inside the housing I would call a technician.
Mar 09, 2008 | Kenmore 22422 Top Load Washer
HP PhotoSmart C4180 All-in-One... Problem:
Try the resetting the printer to factory defaults.
Steps:
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
