Question about Patton (HASF1016UC) Stand (Pedestal) Fan
NEED VALUE OF CAPACITOR ON MODEL 1010MP FAN. CAN'T FIND ANY INFO ON THE PART.
  • 17,130 Answers
You can use any capacitor of value about 3.3mF to about 6.8mF with an AC voltage rating of about 230 to 250 volts.
These are the bipolar type capacitors and is generrally available at all electrical or electronic spare parts shops.
Hope this helps.
Posted on Aug 29, 2010
How do I reconnect the capacitor?
Not easy to explain. The capacitor is split, it has two values, or like two capacitors connected internally with a center tap between them. Two capacitance values, maybe 5uf and 20uf, the lower value for the fan motor and the higher for the compressor, with terminals C-common, F-fan, M-compressor.
Capacitor terminal C is the center tap and that takes 3 connections, line (power) - fan line common to capacitor, and Compressor line common to capacitor. Notice the fan and compressor have a power line not common to capacitor, just power line.
Capacitor terminal F has one wire connecting to Fan terminal C, fan may have three or four terminal writes, two for power with one power being common to capacitor connection and the other power alone, two power connection wire leads. Fan motor third line is capacitor, connects to the capacitor alone. Four wire configuration fan motor is not likely your needs. Omit or ask again for further explanation.
Compressor is similar to fan, only with a capacitance value higher than for tha fan motor. Two power leads, one straight power, the other power lead connects to the capacitor power. The third compressor lead connects alone to the capacitor.
The with is to draw a diagram and level the colors of each lead and terminal lavels too. The motors nameplate may indicate wire color code, the a-c nameplate wiring diagram may be present in the control wron wiring compartment, the goal is to find clues or to trace each wire and verify what they connect or do, take notes on your drawing.
Basically the motor has three terminals, L1 - L2 - C, or C- S-R (Common, Start,Run)
Jul 14, 2015 | Maytag Heating & Cooling
Need to know the values on the duel compositor
The info should be on the side of the capacitor. If its not, it will be hard to tell by the capacitor. You will need to get as much info from the compressor & fan motor. Then call a local parts house(s) and find someone who can look it up for you. Or the comp manufacturer.
Jul 09, 2015 | Heating & Cooling
What is the fan motor capacitor rating for a RUDD model UACC-030JAS
For a fan motor capacitor we need to know what motor is on it. The units model will not help in this case. On the side of the out door units fan motor will be a sticker/tag with a lot of info. HP, volts,rpm.... And somewhere on that tag should be a "cap 5 uf" 7.5uf....
Most likely a 5 or 7.5. if and 370v or 440v rated. Either one is fine when it comes to the 370/440 value.
May 27, 2015 | Heating & Cooling
How part no. CBB61 can replace part no. 84368?
CBB61 isn't a part number. it's more like a 'Type' number. The thing that matters is the uF (microfarad) value of the capacitor. If the uF value is close it (+ or - 1 uF) it will work fine.
May 04, 2014 | Hunter 52" Ceiling Fan With Light And...
NEED REPLACEMENT MOTOR FOR PATTON 1010MP-HY FAN. WHERE CAN I PURCHASE THE MOTOR?
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Aug 17, 2011 | Patton U2-1487 Floor / Box Fan
Fan not turning
Check fan capacitor,disconnect capacitor and measure it with ohm meter,put value on ohm meter ohm x100 or more,measure capacitor
it must show some value but it will be very fast,if there is no value change a capacitor,a new must have same parameters(values) as old
e.g. 80 micro F,220(110,380)V.Note a wire which was on capacitor.
If not capacitor,check fan motor,also with ohm meter,measure all wire for each other,ohm meter must show some value,e.g. 25 ohm.
DISCONNECT air conditioner FROM ELECTRIC POWER WHEN YOU WORK THIS,AND BEFORE MEASURING CAPACITOR SHORT CUT IT WITH A ISOLATED SCREWDRIVER!
Jul 02, 2009 | Ruud Matching Split Air Conditioner
Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
May 04, 2009 | Aloha Housewares (93645) Ceiling Fan
Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Jan 01, 2009 | Patton (HASF1016UC) Stand (Pedestal) Fan
Condenser fan rotation
However, if it is the ORIGINAL motor, check the dual run capacitor for proper microferrad value. It may be that it is swelled up on top and that is a direct indication it is a fouled capacitor. If the top is not pregnant or swelled, and it still looks like the top of a soda pop can, you will need a microferrad meter.
Disconnect ALL power to the condensing unit. If in doubt, kill the power to home. Remove 1 wire from the capacitor, the brown one or the one that is marked "FAN" and set your meter to Mfd, measure with your leads the value between the COMMON and FAN terminals. They should be within 6% of the rating on the capacitor. There is no rule of thumb here, you must know the correct value and see if it is equal or within the 6%. If it is under the 6%, you will need to replace the DUAL RUN CAPACITOR. No question, because it is a dual run cap, it controls the Compressor also. Best to change the whole capacitor with that of equal value.
God Bless.
ACMAN66 (Erik)
May 27, 2008 | Goodman CKL24AR24 Air Conditioner
Patton (HASF1016UC) Stand (Pedestal) Fan Logo
430 people viewed this question
Top Patton Dryers Experts
Tom Chichester
Are you a Patton Dryer Expert? Answer questions, earn points and help others
