Question about Toshiba e800 Pocket PC
Can't turn off pocket pc; cannot tap and select on bottom portion of screen
For some reason, after troubleshooting with IT to sync my e800 to my new computer, I can no longer turn off the device. ALSO suddenly, I can no longer "tap and select" on the bottom portion of the screen.
Do I need a new battery? A new device? Or is this fixable (please!)
Thanks,
Mine won't turn off as well. It'll turn off for a second or 2 and then come back on when it's on the cradle.
No issues with your other problem for me.
Posted on Jul 14, 2008
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
How to install themes
Here is your Pocket PC's default theme
wm6_default.jpg 1. Connect your Pocket PC to your Desktop using your cradle and Microsoft Active Sync, Once it is Connected double click on the green circle on your taskbar to open the Active Sync Window (If the Circle is grey, then it means that your Pocket PC is not properly connected).
2. Now you need to click on the explore Icon.
3. Here you can see the files and folders on your Pocket PC. Navigate to the “My Documents” folder. (This is where we suggest that you put your themes) . You can also use the“Windows” folder or Main directory of a storage card (not in a sub directory).
4.Now you need to drag the TSK theme files that you have chosen from your desktop computer to your pocket pc 5.Now you need to activate the theme file on your Pocket PC:
Tap Start, Settings, Today, Select your chosen theme, and tap OK.
Your new theme will now be activated.
You can download the themes from: http://www.htcfreeware.com/HTC/categories/HTC-Themes.aspx
Jul 14, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Where i get drivers of toshiba poket pc e800
Hey,
you basically need active sync.
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
noting else, active sync contains the driver.
Thanks and good luck.
Ekse
Apr 02, 2009 | Toshiba e800 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
Screen is locked
Mine hp ipaq also froze up, but I tapped the screen until they moved around all in alignment, and I got the basic things back (my programs, Media Player etc. but I can't sync it with my computer. It doesn't recognize the name of my handheld.
Aug 04, 2008 | HP iPAQ HX2755 Pocket PC
How to setup wireless on acer n50 pocket pc
i need help to connect via the wlan wireless connection plese help thanks
Feb 21, 2008 | Acer n50 Pocket PC
Toshiba e800 freeze ups...
ctrl q will close the program
Oct 24, 2007 | Toshiba e800 Pocket PC
E800 spontaneously resets
this hard reset is based on a slack joint. You could test it, if you turn your PocketPC on, and tip on the cover, near the Display or the Battery. If the PDA make a reset, your Pocket PC need a repair.
Sep 08, 2005 | Toshiba e800 Pocket PC
Applications
I use e800 too and I switch them off manually. You are right. All used applications running in background. All of them are listed in “running” tab. Like I said you can switch them off manually singly or all of them with “select all” option.
Toshiba e800 Pocket PC Logo
389 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
