Question about Hoover Vacuums
Our Hoover U8172-900 brush motor is not working. Do you have a wiring diagram so I can determine if the motor circuit board is the problem or the motor?
  • Hoover Master
  • 17,130 Answers
No diagrram is necessary unless you have dismandled.
Check if the brushes are touching the mtor commutator. If not you can easily remove both the brushes and polish the surface evenly .Insert only after cleaning the motor commutator till the copper shines.
Use can check for the continuity of the brushes to show that the armature is working Ok.
Now check the filed winding. Both the windiings must snot show any leak or short to the body. If so the motor is fault.
If field is ok with the resistance check then check for power supply to mtor when switch is triggered . If not check cord and switch.
Hope this tip helps.
Posted on Aug 29, 2010
How do I take the top off my hoover spinvac shampooer
1) test the motor outside from the machine, carefully and do not touch any side live wire.
2( see the diagram simple for help and test the motor, otherwise you must go to the repair shop motor.
God bless you
Jun 18, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
Have a Hoover model S3670 and the beater brush no longer spins. Have checked the beater belt and it is good, did find out that the light bulb in the unit was bad. Any suggestions on how to test the motor...
I usually test the motor with a cord with alligator clips on the wires, and attach them to the black and white wires on the motor ( remove the belt first ). A very common problem with this model was a short circuit developing in the short cord that runs from the nozzle motor into the swivel neck. This is probably where the problem lies. Replacing the cord is best left to someone with experience.
Apr 19, 2011 | Hoover Vacuums
I HAVE A HOOVER SAVVY AND THE BRUSHS WON'T TURN.
there is a small circuit board right above the motor on the base ,look and see if there are any burn marks or discoloration.if the headlight isn't working either then thats the problem .the circuit board.you can get it through all-type vacuum and janitorial 314-275-8006 supply.$18.49.there is a belt that runs up the center from the roller to the geart on the motor
Apr 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My dyson DC15 the brush cuts in and out.
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
Check the above link to see if it helps. It shows you how to break down the DC15 to check for issues. Also try inspecting the circuit board for loose wires. There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
You can try calling their helpline at 866-MyDyson for further help
Nov 17, 2008 | Dyson DC15 All Floors - The Ball Bagless...
I have a Hoover Savvy Bagless Upright. The beater bar does not turn. It does not appear to be the belt.
The Savvy has a brush roll motor, whcih could be bad. There also is a circuit board near the brush roll motor, a circuit board underneath the tool holder, and the switch asm. in the handle. Any of which could be the cause of the brush roll not turning. Just needs to be checked to find what is causing the problem.
Jun 11, 2008 | Vacuums
Hoover savvy motor problem
The problem is the lower roller assembly circuit board fried. It happened with mine as well. I tried to order a new circuit board from Hoover, but they get it third party and don't want the liability. This is very frustrating. I'm waiting for them to call me back.
Apr 07, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover Savvy Model U8181-900 Rewiring
The brush roll motor is most likely what caused the problem to the circuit board. You would look at about $100 or so for the 2 parts.
Jan 16, 2008 | Vacuums
Brush will not turn and lights will not light
the problm is under the top cover of the base,there are some screws on the botton also remove the self adhiesive emblem on the top and remove the screw then the top will come off.ithink what you will find is a burnt circuit board that sets right above the motor
Aug 26, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Vacuums Logo
603 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
