Question about AudioBahn AW1206T Car Subwoofer
I need a diagram for wiring these 2 aw1206T AUDIOBAHN SUBS TO A HCCA 5000WATT ORION AMP NEED HELP
2 Suggested Answers
SOURCE:
  • 155 Answers
SOURCE: Audiobahn AW1206T manual
i was just in AUDIOBAHN.COM website yes it's still thier check it out agian
Posted on May 17, 2010
IS ORION HCCAD5000 AMP ENOUGH FOR 2 ORION HCCA10.2!
No. These subs are rated at 1500 RMS each. So you need an amp that will produce at least 3000 watts RMS at 2 ohm load or if you wire each sub to a separate amp down to 1 ohm...then you will need an amp that will produce at least 1500 RMS. Those subs can handle more than they are rated though.
Sep 19, 2012 | Orion HCCA 10.2 Car Subwoofer
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
I have audiobahn amp an 3 12inch subs my amp keeps kicking into protection whats my wiring opions mono amp adnot sure what ohm the subs are
Hey sound like your amp is seeing to low of indapendece. 3 subs can be hard to wire. please give mre info on the amp and the subs? dual v/c 4ohm subs are 2ohms wired pos to pos. neg to neg.
Jan 06, 2010 | AudioBahn AW1206T Car Subwoofer
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I have 2 jl-w6 subs n a orion hcca 250 amp how do i run wirering
Hello brianmitchel,
From what I am able to determine, the Orion HCCA250 is a bridgeable 2-channel amp that is stable to 1ohm when bridged and outputs 800 watts RMS into that load.
The JL W6's in both 10" and 12" versions are dual voice coil with 4ohm coils so they can be wired to present either an 8ohm load (series) or a 2ohm load (parallel). They can handle 600 watts RMS.
With this combination, the best configuration would be to wire the sub voice coils in parallel for a 2ohm load and then parallel both subs to the amp bridged terminals for a final impedance of 1ohm. The subs will each be getting 400 watts.
In any event, I would not recommend running subs in series. There is some evidence for distortion being caused by something termed "back EMF".
Hope this helps.
Aug 03, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Apr 28, 2009 | JVC KS-AX5500 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
AudioBahn AW1206T Car Subwoofer Logo
234 people viewed this question
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
Professor_V
Professor_V
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
