Question about Kodak EasyShare M863 Digital Camera
How do I connect Kodak m863 digital camera? - Kodak EasyShare M863 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
To what do you want to connect it?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 17, 2012
  • 126 Answers
SOURCE: On my Kodak M863 digital
click review press menu go to copy click photo or all that should transfer photos to sd card .
Posted on May 05, 2009
SOURCE: KODAK M863 LENS STUCK
my kodak m863 fell,and then the lens is stuck!do you think it can be repairable??
Posted on Jul 31, 2009
  • 17 Answers
SOURCE: can kodak m863 be used as a webcam ?
nope
Posted on Aug 02, 2009
BillB-SA
  • 2761 Answers
SOURCE: my kodak m863 camera wont turn on, when i press
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Oct 25, 2009
leepania
  • 1099 Answers
SOURCE: my m863 kodak camera charging light won't turn on
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Posted on Jan 25, 2010
Kodak m863 battery is not charging. It has lain unused in a desk drawer for a few years. Have managed to take a couple of photos but now battery will not charge and cannot use on/off button unless...
First of all cheak your charger,it is working or not Then put your camera bettery under the sun light for some time and clean your camera pin where the battery attached,then chaek it
Jun 01, 2011 | Kodak EasyShare M863 Digital Camera
Kodak M863
Clean the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Do the same to the battery and the charger.
Oct 07, 2009 | Kodak EasyShare M863 Digital Camera
Can i use my kodak M863 as a webcam
The Kodak cameras are not designed for webcam., :)
Sep 28, 2009 | Kodak EasyShare M863 Digital Camera
Can't transfer photos to computer: computer says
try with an external card reader, it's cheap and avoid problems with the camera computer connection
Aug 23, 2009 | Kodak EasyShare M863 Digital Camera
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
Kodak Digital Camera M863 won't upload any pictures.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 29, 2008 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
19 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
