Question about Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor
My D55151 is very new still. I'm probably used it a total of a half hour. I can't get it to run at all. I know there is power in the cord and I've checked the resetable fuse and it doesn't seem to be popped out. Any ideas? Mark
  • kimandmarkja Aug 29, 2010
    Thank you I will give that a try.
    Mark
  • 2,100 Answers
Two things, either the pressure gauge is not set right, like on 35, off 120, etc, or the capacitor is shot already. The only thing it could be besides a blown motor. If you are sure it has juice to the top of the pressure gauge, try and close the points with a plastic comb or a piece of wood, if it doesn't run, check the reset button again. then go to a hardware store that can check and match up the capacitor. I don't think the motor is bad, unless it ran out of oil and seized up. Check it out, hope this helps.
Posted on Aug 29, 2010
Samsung LN 32C 530F1F keeps powering off randomly
probably overheating. hoover out the vents and make sure plenty of air can circulate. a case of suck it and see. lol
May 24, 2017 | Zenith Televison & Video
Computer is dead. hp slimline. anything I can do to jump start it.
A Totally dead PC can usually mean that the the power supply has quit.
If you've ever replaced a power supply
in a desktop (or Slimline) PC, it takes about an hour, but if its your first time, take your time, and
allocate half a day.
3 vital tips:
(1) use proper anti-static techniques, just in case you might happen to touch the motherboard or a card in the option card backplane.
(2) get (or order online) a replacement power supply with a wattage rating equal to or greater than the wattage rating of power supply being replaced - so you can be sure that the new power supply will handle the load offered by your system.
(3) always keep the power supply module from old PCs - they can come in handy when one dies in a PC that you really want to run (even though the older ones dont have the SATA connectors).
Sep 10, 2011 | HP Hewlett Packard Pavilion Slimline...
Takes two and a half hours to run a load of dishes
They probably aren't running the hot water at the sink before starting the dishwasher. You know how it takes time to get hot water at the tap when you turn it on? well the new dishwashers use such little water, that they will fill with cold/warm water, and try to heat it up to 170+ degrees before continuing the cycle
Apr 04, 2010 | Dishwashers
I have a nuvi 1390T Gps it will no longer power on, for a while it has been freezing every now and then but i just used it an hour ago, it worked fine, turned it off and a half an hour later it doesnt even...
You may do some simple power checks, but if they check out, you'll probably need to send it in. Check that you have ample power at least 12v to 14v at the cord and plug.
Dec 17, 2009 | Garmin nuvi 1390T Car GPS Receiver
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Ring on hour and half hour
On a dipslay phone press "Feature 59". It will display the release of the system. LEt me know that.
Apr 21, 2009 | Avaya Corded Phone avaparp18d
Xerox workcentre m 20i does not power up
First of all try unplugging it for a half an hour. Not just turning it off but remove the power cord. Very often there is a capacitor in that power supply filter you have to let discharge totally.The only way that will discharge is to remove all power for a half an hour.
A dead machine otherwise , would he a bad power supply. It is located under the cover where the copies come out. There is also a couple of fuses on that power supply. To access it, go to the left side of the machine, the side where the on off switch is and remove the 2 silver Philips screws on that side. There is also a tab on that cover, so don't be afraid to pull it pretty hard to remove, It will Pop, but not break. There are 3 screws in the metal cover over the power supply to remove the cover, check the fuses, if they are good the power supply is bad. Google a business called The Parts Drop, call Britt and he will have that part. There is a really good chance that unplugging it for the half an hour will work. I have taken tons of calls and canceled calls where that is all you have to do. Let me know please.
The main board is highly unlikely to cause a dead machine, very unlikely. Actually it can happen, but I have never seen a main board cause a machine to be dead.
Mar 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
1613EVS Plunge Router will not operate. Does not start !
hello- had same problem with similar model-- problem is definitely DUST INSIDE THE SWITCH, it must be blown out with compressed air- i had this done at a repair shop (for free) so i don't know if they had to disassemble anything- hope this is helpful
john
Nov 16, 2008 | Bosch Plunge Router
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
117 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
