Question about Sony Cyber-shot DSC-W30 Digital Camera
How to reattach shutter button
The SHUTTER BUTTON of my dsc w30 flew out together with the SPRING... can someone help me how to reattach the SHUTTER BUTTON...
The fix is real easy. No need to take the camera apart.
Order the Shutter Button Release Assembly from Sony. Cost was around $18.00 + tax + Shipping. I received the new assembly in one week.
Note the angle of the old assembly before removing it so that you can line up the new one correctly.
To remove the old button assembly, use a rubber bottle opener to get a good grip. Turn slightly counter clockwise. Then use your fingernail to lift it up. Look inside using a magnifing (sp) glass and find the pieces that broke off, a spring, a small plastic tip and a small snap ring.
Look at the opening and you'll notice two slots, that's where the two little feet will line up. Again using the rubber bottle opener and pressing down slightly, turn the newassembly clockwise. You'll feel it.
Make sure to clean out the pieces that broke off. I couldn't find the spring, now I can't use that little wheel to bring the viewfinder into focus for my eye. LCD is still sharp as are the pictures. Just the viewfinder.
Good luck.
glenn gorman
Sat, 18 Aug 2007 18:50:55 +0000
Whoops: x21083252
Sony Direct Accessories
Posted on Aug 28, 2008
  • 477 Answers
You will need to get a button assembly it is easier than tiring to get the old one to work because little plastic pieces might be broken or missing. this should not cost you more than 15 to 20 depending on who you get it from.Hope this helps.
Posted on May 19, 2008
How do I remove the SD card DSC W40
Gently press down on the card as if to push it further into the camera. The card will pop out enough to allow you to grasp it and pull it out all the way.
Aug 25, 2012 | Sony Shutter Release Button (D00103002)...
Sony dsc-w30 photos taken some blurs, how w to set it right?
With autofocus digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
Finally, make sure that you have not left the camera in Macro mode. This is a special extreme close-up mode offered by some cameras, and it does not allow autofocus on objects at normal distances.
Nov 08, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
The button that you press to make a photo came off the camera, and it won't depress to make a photo now. Is there a spring or something missing? If so, would a local camera shop be able to repair/replace...
Shutter button is available in parts shops and local camera repair shop will replace it.
Sony will charge you too much to replace that button.
Let me know if you have any additional question.
Thanks.
May 17, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
Shutter button flew off on Christmas day. Luckily was indoors. Found the spring and button, cellotaped together and worked fine until yesterday whilst taking photos, the shutter button suddenly stopped...
shutter mechanism inside may not be in contact with the actual shutter button...or shutter mechanism might have failed altogether.this one's definitely recommended for repair.
Apr 16, 2010 | Sony Cyber-shot DSC-H5 Digital Camera
Sony cybershot shutter botton fell off I need a new one
It would cost more to repair than to buy a new one - Contact Sony repair shop to get a new shutter button
Sep 08, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Shutter button popped off & I am out of warrenty.
You can replace it DIY. Here is a link show you how to replace the button and where you can get the parts.
How to replace the shutter button on SONY CyberShot DSC-H5 digital camera
Mar 17, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Lumix shutter button came off
como instalar una camara web con este modelo
Oct 23, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
DSC-h1 Shutter button broken
I recieved my new shutter button from Sony and replaced it after searching on the net how to do so. I used rubber gloves to get a good grip on the button ring and turned it, I believe clockwise, and then replaced the it with the new button and ring. So simple and saved myself a lot of $$ though, $30 seems an awful lot for such a small piece of cheap plastic.
Sep 04, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Shutter problem with a sony dsc-w30 camara
Make sure the battery is strong and not failing you and that the extending lens cover parts are clean. You may have gotten something in there.
Dec 24, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
408 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
