Question about Visual Land VL-847 MP3 Player
It dosen`t want to turn on when it`s unplug. can you help,
Turn signal dosen`t flash
There is a small ice cube relay under dash .If your not sure what it looks like buy one from auto parts store.it just plugs in.to a set of wires on a plug .just unplug the old and plug in the new. Should only go one way.
May 18, 2014 | 2003 Cadillac Deville
I have a frigidaire wall oven which was on bake accidently hit clean and immediately hit cancel. Sounds like fan running and started beeping and F8 appeared. Turned off breaker and turned back on same
Hello - Typically error code F8 indicates that there is a communication error between the user interface and the control board. Try resetting the range by unplugging it or flipping the breaker off. Wait approximately ten minutes. If it proves to be ineffective, contact a professional to move forward accurately.
Nov 23, 2012 | Ovens
2002 dodge grand caravan won't start
Hello, Just by my experience with my 91 dodge grand caravan, I would start checking 3 things. First, did you replace spark plug wires to the correct location(Plugs 1, 3 and 5 on the back, Plugs 2, 4 and 6 on the front,That's all starting from the Passenger's side.) 2nd, do your dash lights and electronics turn on when it turns over? If not, try jumping it and 3rd if engine finally runs after that and then shuts off, then your alternator will be next to check however if engine dosen't start running from trying to jump it then the problem is more than likely your alternator. Though make sure you have plugged in all plugins that you might of unplugged like the one that plugs into your DIS coil pack and all vacuum hoses are connecting. Hope this helps and good luck!
Oct 16, 2012 | Dodge Cars & Trucks
My picture on my WD-65638 mitsubish dlp tv has a slight flicker that is annoying. Is my tv messed up?
There are a number of reasons this could happen and unfortunately not much that you can solve. If you have a backlight control in the menu you could try turning this down to see if the problem is reduced or cleared. This won't help you but the info may help a tech.
Feb 06, 2018 | Mitsubishi WD-65638 65" DLP HDTV
We have a DVD stuck in our Phillips DVD/hard disc recorder, after loading the dvd it would not read it then we could not open the door
Dear helen, I don know if this is possible with your machine but I have removed dvds by either; turning the power off to the machine then turning it back on then trying the remote again or the facia control. I f that dosen't work try unplugging it and using a knife to gently prise the door open then manualy pulling the cradle out. I have done this also without any damage.
Oct 09, 2011 | Televison & Video
How do i turn on the blue tooth in my acer 5742 laptop?
Hi upch505,
Probably your laptop dosen't have bluetooth hardware in it.
Follow these steps:
1. Right click on My computer and click Manage
2. Then click on device manager on left panel
A list will appear which shows the hardware content of your laptop. If the list dosen't contain bluetooth device then it is confirmed that your laptop dosent have bluetooth hardware.
Try using external USB bluetooth device for your laptop.
Hope it helps.
Thank You for using Fixya.
Sep 09, 2011 | Acer Aspire 5742Z-4200 Notebook
When playing games like grand theft auto san andreas which run fine, my laptop will suddenly turn off, and I have to take the battery out, unplug my power source, put battery back in, then put the power...
Sounds like a overheating issuse. Get a can of air or vacuum and blow out any vents.
Also avoid playing games on any soft surface couch bed etc. As that blocks the fans.
If that dosen't fix it it is most likely the GPU on the motherboard overheating and lifting off the board. It is a very common problem.
Jun 12, 2011 | Toshiba Satellite L455D-S5976 Notebook
Aprilia rs 250 dosen´t run under 3000 rpm. It just dies.It hasen´t been driven a lot the last five years. I put new petrol in so that´s not the problem. And the speedometer dosen´t show...
Over time the old gas in the tank formed deposits. The gas in the carburetors left deposits in the small idle circuit holes. The carburetors will have to be cleaned.
The connector to the sending unit for the speedometer may have corrosion on it. Try unplugging it a cleaning the terminals.
Jul 22, 2010 | 2000 Aprilia RS 250
My online for ps3 doesnt work anymore. i dont know why it just suddenly stopped working and hasnt worked for a few weeks now everythings plugged in and nothings changed or anything.
refresh ur router or unplug it then disable your netlock or net filter... if that dosen,t help remove your router password and easy install your ps3
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
Whirpool duet dryer stopped working PF signal
PF MEEN PAWER FAUILER SOME HOW YOU LAST POWER TRY TO UNPLUG AND PLUG BACK IN AND PUSH CUNCEL . IT WILL RESET THE BORD IF IT DOSEN;T YOU MAY HAVE A BAD BORD AND IS NOT TAKING COMAND
Jan 20, 2009 | Dryers
Visual Land VL-847  MP3 Player Logo
Top Visual Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
cwh20002
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
