Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
The flap that closes when the dirty water tank is full keeps closing as soon as I turn on the cleaner (the tank is empty).
SOURCE: bissell pro heat cleaner
My Bissell did this same thing and it took forever for me to figure out. Seems one of my kids turned the dial that says heavy traffic, normal traffic around and around. All I had to do was turn it back until it wouldn't turn anymore and VOILA!
Posted on Sep 23, 2007
  • 12 Answers
SOURCE: Red float keeps popping up
Don't permanently remove the filter, instead, cut approximately 3/4 of an inch off the OPEN end of it and put it back on.
Posted on Dec 04, 2007
tipstir
  • 67 Answers
SOURCE: not sucking up dirty water
Sounds like the suction motor is not working correctly. Either clogged with dirt or objects or it is failing.
Check this first:
Not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening.
If your machine does have suction at the duct, continue to check the following:
Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE
ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
Check the Tank Lid and Tank for damage.
If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection.
Posted on Jul 31, 2008
  • 120 Answers
SOURCE: Bissel Power Steamer Pro
yes you can but it would require taking the entire hood of to replace it ( it hooks on inside there ) but those machines need to be opened very carefully and you need to make sure several pieces are back a certain way, so i would take it to an authorized bissell repair center, go to there website and put in your zip code to find the closest one to you.
Posted on Sep 24, 2008
SOURCE: Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Posted on Jan 14, 2009
We have a bissell lift-off deep cleaner 66e1 and it won't suck up the dirty water what can I do to fix it
Loss of suction power -
1. Tanks may not be seated properly - Pick up both tanks and reseat them so they fit properly on the unit.
2. Nozzles may not be assembled properly - Unplug the unit. Check to make sure the "lip" of the nozzle cover is securely hooked into the groove on the top of nozzle.
3. The portable spot cleaner is not attached completely - Push down firmly to check connection
4. Dirty tank has picked up maximum amount of dirty water and has reached full line - Empty dirty tank
5. Formula & water tank is empty - Check fluid levels in formula & water tank Suction Gate is open Check to make sure the suction gate is closed. Follow "Cleaning Suction Gate" instructions in the manual.
I hope this helps!
Jim
May 27, 2016 | Bissell Vacuums
Bissell carpet cleaner manual
Check the dirty tank for proper assembly and how full it is. There is a red float ball in there that might be stuck closed.
Sep 06, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
    First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
    - Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
    - Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
    - Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
    - Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
    - The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
    - Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
    - If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
    - Check the Tank Lid and Tank for damage.
    Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
    My bissell will not suction water from the carpet
    Please check the following:
    If you continue to experience low suction, please contact BISSELL Consumer Services at...
    1-800-237-7691
    Mon-Fri: 8am to 10pm ET
    Sat: 9am to 8pm ET
    Apr 09, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
    I cant get it to ****
    This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
    http://www.bissell.com/images/UserGuides/9500_908.pdf
    Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
    Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Hoover steam vac
    in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
    Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
    Not sucking up dirty water
    Check this first:
    Jul 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
    No suction
    if this is a 9400 series check and make sure the red flap in the lid of the dirty water tank is not closed.
    Apr 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
    642 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
