Question about Brother MFC 8820D All-In-One Laser Printer
Poor printing quality after replacing drum
I just replaced drum on my Brother MFC 8820D and the copy is all greyed out What could be the problem?
Your drum needs to be cleaned or replaced
Posted on Oct 06, 2008
  • 552 Answers
Have you checked to see if your setting for color is set to grayscale?
Posted on May 07, 2008
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
Drum end soon brother mfc 7320 printer usb002
My Brother MFC 7420 said drum end soon, so I ordered a new drum. Then I waited for something to go wrong before I replaced it. Basically I was looking for a deterioration in print quality. I waited and waited. I think it was over 3 years. I replaced the toner a few times. While the print quality never really went done, the frequency of other problems finally shot up. When I replaced the drum the problems went away. My advice -- ignore the warning unless you have other problems.
Dec 08, 2013 | Brother MFC 7420 All-In-One Laser Printer
Print copies have a grey cast. i replaced the toner cartridge holder but am still getting a grey cast. i have been using off brand toner replacement through amazon. i hope this can be fixed.
it can be that the drum cleaning blade is poor quality or charge roller fault. To avoid the low quality repair of toner crg's and possiblle troubles related to repaird crg burst, use only original supplies or buy from verifed toner remanufacturers!
Sep 15, 2011 | Brother DCP 7010 Multifunction Laser...
Brother MFC-5890CN Printer
It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
Brother MFC 5890 Print Quality
Jan 14, 2010 | Brother MFC-5890CN All-In-One InkJet...
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Print problem
Stop print before fuser to see if error occurs with print or fusering system?
Make sure you have cleaned carona on drum and returned slider to home position
Check if print ok or if it is just copys?... if just copy clean scanner glass slit
You are using OEM drum and toner arn't you?
There is one last alternative but I won't bother to descibe till I get some more info from you
Dec 29, 2007 | Brother MFC-8840DN (Bundle) All-In-One...
Brother MFC 8820D All-In-One Laser Printer Logo
332 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
