Question about Philips Magnavox DVD/VCR Dual Player
E45 error code not recordable in +VR mode - Philips Magnavox DVD/VCR Dual Player
SOURCE: Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
Posted on Sep 29, 2008
  • 6 Answers
SOURCE: DVD Recorder
If you connect a time base corrector box in between the device and dvd recorder, you will have no problem recording anything
Posted on Oct 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: what is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Posted on Jan 10, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: get an error when i try to record
The strange thing about the Philips DVD players is that -R and -RW discs automatically record in +VR Mode. If the current discs you are using are -R/-RW's, then switch to +R/+RW, but usually you have to do the opposite - you are probably recording on +R discs - just switch to -R or -RW discs. All the Philips recorders do this to one extent or another. Good luck!
-Tha Mp3 Doctor
Posted on Mar 21, 2009
  • 6 Answers
SOURCE: I Have a Magnavox MWR10D6 DVD Recorder
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Posted on Nov 12, 2009
Error Message: Cannot record in VR-mode?
To be able to help you, tell me these things: What type of disc are you using (-R,+R,-RW or +RW), was the disc previously used in another recorder or computer, are you attempting to record in VIDEO or VR mode and have you done any formatting to the disc?
Jul 17, 2014 | Toshiba Dr430ku Dvd Recorder - Black
I'm trying to copy a tv show from my DVR and the recorder keeps saying Recording Error This program is not recordable in +vr mode. What is +vr mode?
Recording mode is set wrong, change it and try again unless there is an anti-copy signal on recording which some money hungry cable companies do to screw with customers.
Sep 01, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
My VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
Jun 11, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
What is VR mode and Video mode on a dvd recorder?
ne sesito plano de este equipo urgente aiwa cx-naj50u
Aug 13, 2009 | LG Audio Players & Recorders
Get an error when i try to record
-Tha Mp3 Doctor
Jan 10, 2009 | Philips DVDR3545V/37
What is +vr and how do I remove it
Sep 28, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox ZV450MW8A can't record
Just set the channel to a non-premium channel (ABC, CBS, PBS, etc.) before starting the dubbing process.
Apr 20, 2008 | Philips Magnavox DVD/VCR Dual Player
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
217 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
