Question about KitchenAid Dishwashers
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
  • 5,081 Answers
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Posted on Aug 29, 2010
I know this answer is old, but I found it during a search today (03/21/16) so I am posting this comment:
If the inside of your dishwasher is stainless steel, do NOT use bleach!!
You can try putting 2 cups of vinegar in a heat-safe measuring cup and run your dishwasher through a full cycle. Vinegar is also an acid, so this method is recommended by Kitchenaid rather than pouring it in the bottom and allowing it to sit there.
If the inside needs scrubbing, the recommendation is to use a paste made with dishwasher detergent (or liquid dishwasher detergent) and a sponge to clean the interior.
A baking soda paste is generally safe also. If you want to scrub with a baking soda paste and then add vinegar, I would recommend scrubbing with baking soda first and then add vinegar. I suggest limiting the time you let the vinegar sit to no more than 5-10 min. before rinsing.
Posted on Mar 20, 2016
Help! The dishes on the top rack of my kitchenaid dishwasher (KUDS01FKPA0) don't get clean. this problem started last year, and two different things may be happening. A guy replaced a part (a screen with a...
The part he replaced (chopper) is a common problem with this particular machine. If he has removed all residual food particles from the machine, and you have done your part to rinse them thoroughly before loading, I doubt you have the same issue. There could be other possibilities. One: The water inlet valve could be restricting, thereby not allowing the the proper amount of water into the machine. Two: The internal pump impellers may be worn, and not propelling the water upward enough to reach the top rack. Hope this lends a little insight.
Nov 04, 2013 | KitchenAid Dishwashers
Poor rinse on maytag model mdb8600awq
Did you check the screen at the bottom of your dishwasher? It may be clogged with food particles. If these particles aren't small enough to get flushed down they will just recycle through the water.
I always make it a practice to rinse off my dishes before I place them in the DW. Some newer models have better drainage systems, but perhaps yours is an older model.
Dec 22, 2012 | Maytag Dishwashers
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
White film and food particles on dishes
Did you check the incoming water quality, regarding hardness!
If your washing machine supports salt addition technique, fill the appropriate box and fill the salt that is meant for washing machines. Salt works as a softener.
Finally check your rinse aid also for it's fill in the dispenser meant for it
Apr 11, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Food particles left on dishes
Many times this caused by food particles clogging the screen or blocking the jets on the spray arms. Find the screen in the bottom of your machine and clean it out. If this doesnt help, remove the spray arms and clean them out.
Jun 17, 2009 | Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwashers Logo
1,011 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
