Question about Jenn-Air Ovens
Was Cleaning the Oven and F codes came on and could not shurt the oven off
  • kenmerl2 Aug 29, 2010
    I turned the power to the oven off to see if it would reset. When I returned the power and tried to reset the clock an F2 code appeared and the oven came back on. It heated back to the cleaning heat but was not locked. We again could not shut it off and I again turned off the power. We need help.
    Ken
    Brigadier General:
  • 3,513 Answers
Hi
Since you have not mentioned the error code number specifically ,it is hard to suggest any advice…. turn the breaker off to reset the unit and see if it functions normally.
Also check this link for the error codes and the resolution to that…hope it will help
http://www.repairclinic.com/0078.asp#JennAir
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 29, 2010
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
What does an F3 trouble code mean? We were using the self-cleaning feature when this came on. We were cleaning it because we thought it might help the thermostat, which has been keeping the oven running...
Hi, F3 code means Shorted or open oven temperature sensor (RTD)
Solution Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 10, 2010 | Maytag Ovens
Oven door won't unlock
kenmore selfcleaning oven door will not unlock code f9 appears in window
Jan 03, 2010 | Ovens
F-2 code
HI. this code can come up for two different reasons. it could during a bake session or a cleaning situation as well. I will list the details below.
During Baking(((f2)))
During a baking session, if the control senses an active oven temp above 615f-630f, this code will appear.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
During Cleaning(((f2)))
During a cleaning session, if the control senses an active oven temp above 915f-930f, this code will appear.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Aug 02, 2009 | GE Ovens
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Whirlpool oven caught fire while cleaning
just scrape out the residue and clean it again.
Dec 12, 2008 | Jenn-Air Electric Double Oven
Ovens Logo
64 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
