Question about Nokia 5300 Grey Cellular Phone
Camera stuck on standby
Every time I take a picture with my camera phone it doesn't happen...it stays locked on "camera on standby". What do i do???
  • murderlina May 20, 2008
    I have the same problem. I've realized that if you mess with where the pictures are saved then it goes away. But mine has come back. ):
  • jassbhatia Jun 09, 2008
    hi, i am facing the same problem. earlier i though that there might be memory problem and i deleted many pics songs and videos but its still showing this message.
    Brigadier General:
  • 7,752 Answers
What you should do is take the phone to a mobile center and ahve the firmware reflash on the phone to correct this issue
Posted on Jun 29, 2008
Flashing standby light 13 times and doesn't stay on, it turns off instantly
A brand and model number might be helpful for a educated answer or possible things to look at.
Dec 04, 2012 | Televison & Video
Tip
Avoid "Camera on Standby" glitch with MicroSD
If the camera function will not save a picture and instead gives you the "Camera on standby" warning, but your phone is otherwise working, and you haven't used up all your memory, the problem might be with the MicroSD card. Many Nokia phones format MicroSD with, I think, FAT16, which limits the number of files that fit in a given folder to 256. You may have just filled up the camera memory folder with 256 files and you need to delete some or create a new folder on the MicroSD and use that as the new camera memory bank. Happened with my Nokia 6126 a few minutes ago and I was PISSED until i realized the quick fix.
on Apr 01, 2008 | Nokia 6126 Cellular Phone
Camera doesn't turn on
make sure you take your camera off of lock and put it on standby after turning it on
Sep 26, 2012 | SiPix SP-1300 Digital Camera
Can't use Camera it say: "Camera on Standby
hi there!
the camera really goes on standby when you turn on the camera but you wont use it for a couple of minutes. but it should come alive once you press the camera button or any keys. if thats not happening, it may have been stuck there (if there are many programs open at the same time, its going to hang) so just powercycling the phone (turn off, remove battery, simcard, memory card) leave it like that for 2mins, put everything back in. if after turning it on, the camera still on standby, you may need to take to out for repair since there's no safe software out there i will recommend to reset the phone, better safe than sorry right =)
Apr 12, 2011 | Nokia N95 Cellular Phone
My canon digital camera is otherwise o.k. b ut when taking in picture made, the screen stays dark and i cannot take pictures. this happened once before but through internet solutions i could solve it. can...
A stuck shutter is another common failure mode for digital cameras, especially for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. This time if you fix it, remember to take many pictures afterwards to lubricate the shutter to prevent this from happening again.
Apr 05, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Sony A300 and the pictures are off center. It looks fine in the viewfinder but then the picture will be off to the right. Any ideas on that?
This happens when the CCD sensor in the camera gets stuck off centre. It apparently happens sometimes if the camera body is dropped or knocked - it's a fault with the 'slider' on which the sensor sits. When you turn the camera on the software will shake the sensor to remove the dust. The sensor should then be centred by the camera's software. If this doesn't happen then the picture is clear but off centre as in your case. Usually this means a trip to a repair shop.
Feb 28, 2011 | Sony Alpha DSLR-A300 Digital Camera
Sometimes when I want to take a photo my phone indicates that camera is on standby and camera does not work. When I take a photo the phone shows :"operation failed" and then freezes up for a couple of...
nothing is wrong with the phone, it is a normal function in every phone. If u leave the camera open for some time, it will go on standby mode, u have to turn it off. so better is that the moment u take a picture and there is a gap in taking the other picture, u turn the camera mode off. when u need it again, then again put it on.
Sep 12, 2010 | Nokia 6303i Cell Phone
Nokia 5610-camera on standby
Its not a problem with the mobile its common in all mobiles when we keep the phone in camera mode for more than 30 to 40 secs.we should take the picture within that time or will go to standby to save charge.just click on continue it will come back to camera mode but if you have this problem without any withstand time(30 to 40)then contact your mobile vendor.
Oct 11, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Camera turns on with a bit of a tremble but shutter locks
I have an 5D with the same problem, It looks like the Anti shake does not initialize properly, The only bypass I found that worked (except for a real repair) is to set the display light timeout for 5 seconds, The standby timout for 1 minute, Turn the camera off, and on again, Wait for 5 sec then the display goes blank, wait for 1 minute then the camera goes in standby, (light from CF card flashed red 1 time) Then touch any button to re-activate the camera and... voila... everything works, including taking normal pictures and the anti-shake !!! So it only takes a minute everytime to startup..
Jun 05, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Nikon Coolpix 5700 malfunction
It sounds like the Function (FUNC) button is stuck. Actually, that's what is supposed to happen if you press the FUNC and then turn the wheel... but it's not supposed to stay that way after the FUNC button is released. Try tapping the FUNC button to see if it releases.
Nov 17, 2008 | Nikon Coolpix 5700 Digital Camera
Nokia 5300 Grey Cellular Phone Logo
123 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
