Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
I installed a Liftmaster 3800 garage door opener, when setting the closure door will not close and the drum unspools the cable. Do I need more spring tension? Or does the door not weigh enough?
My door does the same thing, I could not raise the rear of the track to get a slope on door due to clearance of garage lamp. So i made a bracket to hold a compressed gas shock to push the door the first 10 inches to help it get moving then gravity takes over. Total of 50.00 invested
Posted on Oct 01, 2012
  • 504 Answers
If you can raise the backhang 3 or 4 inches this will keep tension on the cables. This is a very nice system, however the door must work well for this system to work.
I would also spray WD-40 on the roller shafts, spring and spring shaft bearings.
If you can't solve this, then you may need to have a pro look at it.
Hope this helps,
Steve
Posted on Sep 20, 2010
    Scholar:
  • 143 Answers
This is better left either to a pro or a phone chat of some kind. Thanks BB
Posted on Sep 05, 2010
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need a new garage door opener, but only have 121.5 inches from front wall to an annoying bulkhead. One installer said I needed 124 inches for a standard opener. He told me that my only solution is to...
CHECK OUT THE MODEL 3800 BY LIFTMASTER
VERY NICE UNIT - WE INSTALL THESE WITH GREAT SUCCESS
I WOULD NOT TRY TO CUT DOWN A BELT DRIVE
THE CHAIN DRIVE LIFTMASTER CAN BE CUT DOWN
HOWEVER I WOULD STILL GO WITH THE 3800 SERIES
Feb 07, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a LiftMaster garage door opener.When the door closes it is not completely closed on the right side. It has about a 1/4" gap at the bottom. It starts closing evenly but when it is about 2 feet...
SOUNDS LIKE YOU MAY NEED A SERVICE TECH.
IF THE CABLES ARE NOT RUNNING PROPERLY ON THE DRUMS IT WILL CAUSE THE PROBLEM YOU DESCRIBE. OR THE DOOR COULD BE CATCHING ON SOMETHING (DOOR JAB, TRIM ETC.) AS IT CLOSES.
I DON'T RECOMEND TRYING TO ADJUST THIS YOUSELF A PRO CAN DO IT IN ABOUT 10 MIN. IF YOU START MAKING ADJUSTMENT WOITHOUT KNOWING EXACTLY WHAT YOU ARE DOING YOU WILL PROBABLY JUST MAKE IT WORSE.
THE SERVICE CALL SHOULD BE $ 50.00 - $100.00
ALSO DON'T CALL A HANDYMAN ETC. ONLY A QUALIFIED DOOR REPAIR TECH.
HOPE THIS HELPS
Oct 26, 2010 | liftmaster Chamberlain Garage Door Opener...
Installed garage door opener and the door opens then closes on its on
The down limit switch could be set to low. Try moving the screw clockwise to raise the stop point.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not stay closed. It raises
On the side of the motor unit you will find the 'down limit' control. Turn this in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door closing all but an inch then pulling back up
You can hold the smart/learn button in for 6 seconds and this erases the memory of the logic board. Then you must program your remotes and keypad.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Overhead garage door
You have a problem with the cables. One of the cables might be broke or off the drum
Oct 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
187 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
