Question about Ovens
My oven will not heat up. When I turn the oven on the lights indicate that the oven is on but it never heats up. The stove works fine.
  • 139 Answers
Check the back element to see if it is burnt out ...this is most likley the problem use a flash light to inspect ..to replace the element unplug range..remove racks remove the 2 screws holding the element.. in the back of oven..remove screws on the element to dissconnect the wires ../install new element ..take the back off the range to view all them wires an switches inspect all the wires an switches ..look for burnt wires or broken wires .P/S inspect all wires an connections if bake element looks fine ...good luck ,.let me know if you need more help../joe/
Posted on Aug 29, 2010
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
The oven will not heat. The stove, oven light work fine. Just that the oven will not heat.
Probable cause of that is an open heater - no connectivity. As you know the heater is the one that produce heat in the oven. So when it has a problem even when the light oven light up, expect there be no heating happening. Also the wiring that connected to it.
I hope my advice give you an idea.
Mar 23, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I have the fisher paykel pepper electric stove top and oven at home. the stove is working just fine, but below it the oven turns on but it doesnt heat up. what should i do?
When you say that the oven turns on I assume that the oven indicator light is working. If this is so there will be only two likely causes for the oven not working.
Oven element is faulty - check by performing continuity test;
Wiring at oven element terminals burnt off - check visually.
If you are handy carry out the above. If not, call a repairman.
Feb 15, 2011 | Ovens
Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
Mar 01, 2009 | Ovens
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Mar 17, 2008 | Ovens
Ovens Logo
110 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
