Question about Tomtom ONE GPS Receiver
When trying to enter a certain letter on the touch screen, the letter above or below the correct letter appears. Also, the screen freezes at times and I can only get it off that screen by plugging it into the computer. HELP, I am a home health nurse, this is my lifeline!!
  • 3 Answers
You may have to calibrate your touch screen. This is typically in the utility or setup menu. You also may need to do a hard reset. There should be a recessed button that will reset and reload the software.
Posted on Aug 29, 2010
Draw something is seezed on Georgette t. When I enter the last letter of her drawn word the program freezes hav tried many times. Tried skipping nothing works
Try to restart your device like this: Hold down the power and home button at the same time. Keep holding until you see the apple logo appear. Do not release the buttons or touch the screen before the logo appears
Feb 15, 2013 | iPhone Apps
It wont print wireless
We have to connect the printer to the network first, If it is not connected, please follow the below steps.
  1. Touch Setup (c01629002.gif ) on the touch screen.
  2. Scroll down in the Setup menu, and then touch Network .
  3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
  4. Touch the name of your network.
  5. If the list does not contain your network name, follow these steps to enter it manually:
  6. Touch Enter New Network Name (SSID) .
  7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
  8. When you finish entering the new network name, touch Done , and then touch OK .
  9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
  10. If prompted, enter the WEP or WPA key:
    1. Touch the appropriate letters or numbers on the on-screen keyboard.
    NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
  11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
  2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
After that, please note the ip address of the printer from this printed page and follow the below steps.
Please click on Start------Control Panel---Printers Folder.
Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
The issue will be fixed.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My touch screen keeps messing up, certain letters dont work.
I recommend you backup your favorites.
Then attempt a hard reset.
Finally, replace the firmware and system software using webupdate.
Replacing the system software will most likely correct the malfunctioning keying of letters.
I hope that helps.
Apr 03, 2010 | Garmin nuvi 205 GPS Receiver
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
Certain letter keys and number keys on keypad don't work
Try cleaning the screen with a soft wipe and if that doesn't work your touch screen digitizer needs to be replaced (~$200). Is it a 3G? If so I would schedule an appointment at the Apple store to get it replaced.
Feb 11, 2009 | Apple iPhone Smartphone
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Pioneer avic d2 touch screen issue
my touch screen is working but there is no picture
Dec 12, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Freezes at pin request
Can you enter the PIN number? Is the touch screen working? Many times a unit will appear to freeze when the problem is the touch scfreen. You need the PIN number and a working touch screen in order to get back into the Garmin and restore to default.
Nov 20, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Phone freezes when i enter letters
I would reset the phone to factory settings and start over. Do you have the manual?
Jun 24, 2007 | Motorola Mobility RAZR V3
Tomtom ONE GPS Receiver Logo
197 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
