Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Our Superba side by side has stopped cooling on both sides. We've cleaned the coils at the bottom of the fridge from the front panel. There continues to be a clicking sound, but the interior is not getting colder.
  • KitchenAid Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 29, 2010
Describe your Superba Architect KSCS25INSS Side by Side Refrigerator Problem - fridge has power - lights on - but not cooling freezer or fridge - no noise coming from fridge -
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | KitchenAid Superba Architect KSCS25INSS...
Unable to sufficiently cool freezer as of couple days ago; temp higher than freezing point. The metal frame running between fridge and freezer is burning HOT to the touch; so hot that the rubber door...
check the coil to see if it needs to be cleaned and pull out the machine,if it's getting that hot the condenser fan motor could be dead.pull it out and remove the bottom panel in the back and make sure the fan is blowing and clean the condenser coil.the fan motr part number is W10124096 and it's around 85 to 90 dollars.if the fan isn't running you can stick any fan back there to cool down the compressor and get the fan motor as soon as possible,i've found mice stuck in the fan going for water in the pan or papers,if something is jammed in the blade hopefully when you pull it out it will still run but i think this is your problem,good luck.one more thing the model number you sent isn't the full number,you're missing a number on the end the model i looked up ended in 1 but the fan should be the same,you can open the fridge door,look up near the ceiling on the right hand wall and you should see the model number,if it's not there,look down near the bottom hindge on the fridge door,you might have to remove the bottom kickplate to see it,give the number to your parts store and they will sell you the correct part.
Apr 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
Fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
68rjszndh
May 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
My kitchenaid superba ksra22fkss fridge side not cooling and freezer side has large amount of ice buildup on rear wall and bottom
open freezer side and check if the inside fan is running if it is then you may need to replace the heating element around the evap coil
Jul 03, 2009 | Refrigerators
Access to clean coils on kscs25inss00
You need to get a bottle brush they are about 18" long maybe longer and made for getting into these area's to clean the coils. My frig is set up the same way and hate it. Cause when they are that dirty cause's so many things to happen all bad. I have used my air compressor to blow them clean and then chase little dust bunnies around the kitchen. I have been thinking about this same problem for awhile now and bottle brush is the best option for now that I have heard of. ken
Jan 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba 48 Refrig
hi, is the fridge cold enough.pull fridge from wall, remove back panel. clean all coils. this should solve the problem. thanks the appliance doc
Oct 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba fridge not cooling
Check your evaporator fan, defrost thermo., or defrost heater. One of these parts out are what causes ice to buildup on your evaporator.
Sep 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side refrigerator
First thing I would check...is this unit frosting up? Turn it off for two days...with the doors open...to defrost completely. Clean out the condenser coils with a brush. Inspect and clean any gaskets not sealing. When restarting...open up the back panel and check the compressor. It is that big black thing. Find and clean off the largest pipe. Watch the pipe...It will frost initially on startup. Does the frost remain after 5 minutes or turn to ice, water or dry out? If still frosty, you are low on gas. If other conditions, then you either are opening the door too often, those gaskets are damaged or you have defrost issues.
Jun 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
475 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
