Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
What tool do I need to adjust the high & low speeds of the carburator for my Poulan Predator 35cc chain saw because it will not idle at the proper speed.
  • 3 Answers
Wish it was that easy on my polan pro. It took a special driver to fit it and adjust it. The adjustmen had no tip on it. Only round. THe special drive looked like a small driver with a hollow tip on it.
Posted on May 03, 2013
  • 2,100 Answers
Should just be a little bladed screw driver, most are, turn the screw very little, 1/4 turn at a time till something changes, they are sensitive. If you run out of adj and nothing has changed, turn the screws in all the way, both of them, then out 1 1/2 turns, this will get you running, you can fine tune from there.
Posted on Aug 29, 2010
My choke will no stay out on my poulan chain saw
Sounds like the choke latching system is not fully engaging if it is the W28 and on the P3516C. Some minor teaking of the latch may be all that is needed.
Jan 01, 2015 | Poulan Predator P3516pr 35cc 16" Gas...
How to adjusted the high and low in a ryobi rcs3535c4
The initial hi and low jet settings are in the owner's manual or sometimes stamped on the side cover next to the carburetor. If you do not have a manual go to lawnandgarden.manualsonline.com to get one.
Oct 04, 2013 | Garden
How do you adjust the idle on th poulan p3314 gas chainsaw and is there a special tool you need it just wont idle
Most poulan chain saw have three screws idle, high, and low.. if you look air filter cover you will usually see three holes and the high and low will usually have plastic covers on it.. adjust the low 1/4 of a turn and the idle screw in about 1/4 or until the idle picks up... On the plastic cover where the three holes are you will see H which is High L which is Low and I which is Idle... Let me know if you have any problems.. thanks
Jul 16, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
My Homelite ZR10926 16-Inch 33cc Ranger it is starting, idling, it dies when I accelerate it. I assume is the carburetor, maybe ? thank you.
It probably is not getting enough fuel. Check the filter in the tank. If it has been sitting with stale gass this filter plugs up.
Try running the engine with some choke. If this helps, try adjusting the carburetor high speed screw.
Jun 04, 2011 | Homelite ZR10926 16 Chain Saw
How to set carborator adjustment on Poulan Wild Thing 2375?
hello,the starting point for adjustment screws is 2 turns out.turn in til lightly seated so as not to damage them. there are 2 or more style carbs used on saw,some have plastic caps that need to be removed(a small metal screw used as a corkscrew or pry off) or you need a special tool -splined.set high spped til runs good and back off an 1/8-1/4 turn so you dont burn it up. fine tune low spped so it accelerates when trigger squeezed and re check high speed adjustment.single screw is for idle spped-raises or lowers-if chain turns while at idle back off screw.
mowerman33@verizon.net
Oct 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have predator and wont start
Does it have good compression? Is the muffler plugged? Is the spark plug wet after trying to start? If not, try a little starting fluid in the plug hole, and try to start. If you get a few pops, try resetting the carburetor H and L jet screws each 1-1/2 turns out from CW stops. It should run with these settings. Warm the engine up, then apply full throttle and adjust H CW until it runs fast, but 4-stroking. It should smooth out when cutting. Next, set idle L for fairly smooth idle, yet follow the throttle without lag. Adjust idle speed just below chain movement. Hope this helps.
Sep 10, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
"L" adjustment screw on the carburator
L is for idle speed mixture and H is for full throttle mixture. Adjust H, when engine is warmed up, with full throttle--adjust for high speed, but 4-stroking which should smooth out just as soon as you start cutting. Allow to idle and adjust L for smooth idle, but rich enough to allow the engine to 'follow the throttle'. Set idle speed screw to just allow the chain to stop moving.
Aug 06, 2009 | Poulan PP4218AV 18" Chain Saw
Husqvarna 51 wont stay idleing
those are the throttle adjustment screws H is high L is Low for the air mixture of the idle.
Jul 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
What is the "T" adjustment on my Poulan Wild Thing?
The "T" position is just a mechanical stop for the Throttle.  It adjusts the idel speed by keeping the throttle from closing all of the way.  The "H" and "L" screws adjust carburator jets that feed the motor at High and Low speeds.
Apr 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
355 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
