Water leaking into tub from inlet
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off.
  • Tawny1 Nov 30, 2008
    I have a whirlpool Model LST9245AW0. I tightened the water feed valves as they were slightly leaking. Still having the problem of a slow drip into the washing machine tub. Am wondering if I should just get a new machine (it is 15 years old; however, it is has held up so well. Getting someone out to replace a part may cost 1/2 of what it would cost to get a new machine. Just worried about the long-term quality of a new machine since I understand my current old machine is like a workhorse.
    Novelist:
  • 177 Answers
You need to replace the water valve. Look on line for parts for your model
Posted on May 13, 2008
A solenoid is bad on the water inlet valve and needs to be replaced. Here is a link to the part to order.
Nov 05, 2012 | Frigidaire GLWS1749A Top Load Washer
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
Water accumulates in the drum
Hello there There could be a couple of different reasons why this is happening first look at this Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve Next Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. and last is the drain pump it'self if it is wearing out like they will eventually do it is time to replace the drain pump ok so please look into each of these and keep me posted on what you have found and i will send you some more information if needed Best regards mike
Jan 09, 2011 | Washing Machines
Water continues runninng into the washer even after turning off the washer
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 08, 2011 | Whirlpool AWM6100 Front Load Washer
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off. This is a stackable washer/dryer.
Jan 06, 2011 | Washing Machines
My washer will not stop filling. it will continue to fill and overflow. What do I do?
Hello there:
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 03, 2010 | GE WJRR4170E Top Load Washer
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
Water is leaking out from the bottom
If the washer leaks all the time, check these:
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for details.
If the washer leaks only during the fill cycle, check these:
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Oct 26, 2009 | GE WBSR3140DW Top Load Washer
Washer leaks out of the bottom. checked drain hose it is not plugged, checked hot and cold water hoses they're ok.
REMOVE THE TOP OF WASHER AND CHECK THE WATER INLET VALVE. I HAVE DONE EVERYTHING AND FINALLY DISMANTLED THE WASHER UNTIL I FOUND THE HOT WATER INLET VALVE WAS LEAKING FROM THE TOP AND DRIPPING DOWN THE TUB AND ENDING UP ON MY FLOOR. IT WILL DRIP EVEN WHEN THE WASHER IS NOT ON DUE TO THE PRESSURE BUILT UP ON THE VALVE.
Oct 25, 2009 | LG WM2688HWM TROMM SteamWasher
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Washing Machines Logo
903 people viewed this question
Top Washing Machines Experts
