Question about Bose 3·2·1 II System
Bose 321 how did you get the unit open? I dont see any screws thanks
  • lcmg Jun 09, 2008
    bose 3-2-1 gsx door wont open.
Open the cd tray take of the bit that says bose close the cd tray again and you should see the screws? hope that helps
Posted on Jun 23, 2011
To get my unit open I hit on/off and the source button at the same time. Then open showed up on the 3-2-1 window, then I hit the eject button. It works fine now.
Posted on Jun 12, 2008
Bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
Aug 02, 2009 | Bose (321GS) System
My BOSE 321 GSX, was working just fine. I was listening to a CD and started storing it, then someone else tried to stop it, and pushed the on/off, source and eject buttons at the same time. Since then it...
you can open it up and see if you have broken the ac/dc converter. disc tray could have jammed it up. if you dont know much about them then try calling customer support. ^^
Jun 14, 2009 | Bose 3 2 1 GSX System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
My bose 321 won't play DVD only CD
your problem is very easy just open the unit and replace a new one lens or maybe if you dont understand just text me and i help you without any cost 09202838700 challenger3_73@yahoo.com
Mar 10, 2009 | Bose 3·2·1 II System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Jan 26, 2008 | Bose (321GS) System
Bac speaker bose 321
The arrays from this system are only designed to run with the Bose Acoustimass / subwoofer, which in turn will only work with the Bose DVD player. If you use them directly to an amplifier, they'll sound poor / wierd and you probably blow the drivers. You might even damage your amp.
Each speaker has 2 drivers firing in slightly different directions. The idea is (when its used with the 321 system), the inward speakers give a mix of front and centre, the outer drivers give a mix of front and rear. A normal amp won't do this....
Nov 28, 2007 | Bose 3·2·1 II System
Bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Bose 321 Horizontal messing up
if you are a tech look into the horizontal circuit there is cap near the HOT that could be defected also check the yoke it could have a open connection good luck
Jun 04, 2007 | Bose (321GS) System
Bose 3·2·1 II System Logo
281 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
