Inbound faxes intermittantly issue
Intermittant inbound faxes have lines like barcodes streaked all across the pages. Fax repair guy blames the phone line. AT&T tests the line perfect. Landline phone on the line--the quality is perfect. Unplugged the phone line and the power for 5 minutes...so far we haven't rec'd any more faxes with streaks...but this has been an intermittant issue.
I thought your service was no charge...I'm all good. Thanks!
Posted on May 08, 2008
Lexmark pro 705 Phone Line in use error
Try to plug in your printer straight to your wall jack. You can also try using a different phone cable.
Apr 19, 2012 | Lexmark Platinum Pro905 Wireless ALLin-One...
WE HAVE A FAX MACHINE THAT HAS A BLACK LINE GOING DOWN THE PAGE WITH FAX IN AND FAX OUT
For outgoing fax lines, check your scaner rail for any streaks, dirts or similar and clean scaner.
For incoming fax streaks, you can only check your drum unit for lines on surface and replace it, or lines is there because other side has dirt or similar on their scaner.
Hope that helps!
Aug 09, 2010 | Office Equipment & Supplies
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Can't send or receive fax hagans@loadednet.com.au
Check the cable, i.e. plug an analogue phone into the cable and listen for a dial tone. If none, are you plugged into a digital line?
If a dial tone is heard, is it an intermittant dial tone (message waiting) because this can stop the fax from working. If so, resolve this and try again.
Do you need to dial a number to get an outside line? If so this needs to be entered before the fax number on outgoing faxes.
Nov 17, 2009 | Canon MP830 All-In-One Printer
Large Black streak on outbound fax/copy
1 or 2 LEDs are burned out in the scanner unit.
Sep 23, 2009 | Brother IntelliFAX 4100 Laser Fax
I have 1 phone line that is shared with my all-in-one fax, therefore, we are using the phone/fax in DRPD mode but I am unable to receive incoming faxes. The fax machine is a Samsung SCX-4521F.
I would get a line sharing device. That device will be able to establish wether the inbound call is a fax or voice call, and route it accordingly.
Jun 09, 2009 | NEC Electra Professional ETW-16DC-2
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
Fax allows only 2 pages to be fax from outside
Noisy/faulty phone line could do it causing communication to fail after so many errors (need filter if ASDL), or could be having trouble picking up paper (check by doing multipage copy) or of course it is sending fax prob but I take it you mean customerssss faxssss
Thats about all it can be.
Nov 19, 2007 | Canon FAX-L900 Plain Paper Laser
70 people viewed this question
k24674
jasbo
jasbo
