Question about Kirby Ultimate G Bagged Upright Vacuum
When I replace the rubber on the cylinder and return the lever handle to it's original position in order to close it, the rubber comes off. How may I resolve this frustrating problem? thanks, bw
    Champion:
  • 274 Answers
See if the clip that holds the belt is not bent make sure the belt is hooking on and getting hooked on to the engine shaft.
Posted on Aug 29, 2010
I can getmy lever to come down
I don't have the same model, but the same problem. I found that if I rotate the handle of the height adjustment it allowed it to work, anf the problem didn't return.
Aug 24, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Hoover model U6425-920 falls backward
It sounds like the handle release lever is bad if the unit will not stand up. It's common when those units get a little older. It is unlikely you'll need the rear handle assembly (the part with the filter housing) but it does happen. Inspect the latch on the handle assembly to make sure it's not too worn to know for sure. Chances are, the handle release lever is just spent.
Here's the part you're looking for:
http://vacuummedic.com/product.php?id=171
As long as you're into it the belts and roller are always a great investment. Replacing them will make it clean like new again. I'll include the links for those parts as well.
Flat Belt:
http://vacuummedic.com/product.php?id=6
V-Belt:
http://vacuummedic.com/product.php?id=485
Brush:
http://vacuummedic.com/product.php?id=484
Happy Vacuuming!
The Vac Dr.
Dec 27, 2012 | Hoover Ultra U6430-900 WindTunnel Bagged...
Sebo Automatic X1 Stopped. Yesterday my Sebo stopped working. I know this can happen if it gets blocked and overheated so I checked for blockages, none. And left it too cool down. Tried it again but it was...
Ok, thanks for the clarification. Even though the cord doesn't have any external damage, it's still very possible that it has gone bad. When a Sebo upright doesn't even start, this can mean one of several things. The parts that could go bad that would cause the machine not to turn on would be the cord (most common on a Sebo), the on/off switch, the PC board that's on top of the motor, or the actual motor. In the 7 years that I've been selling Sebo, I have only changed out one PC board, and I've never had to replace a single motor on a Sebo yet. I have had to replace several cords over the years, some showing external damage, others didn't show any damage.
The cord and the switch are going to be the easiest parts to test, and also happen to be the most common, so this is a great place to start.
Here's how you can test the switch and the cord on the vacuum cleaner. You'll need to have a simply Electrical tester that will test if current is going through the cord. Here's a link to a similar one that is very inexpensive that I used in this repair solution:
http://www.homedepot.com/h_d1/N-5yc1vZ1xh7/R-100183054/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Step 1. Unwrap the electrical cord from the vacuum cleaner, and set the entire cord aside. Also remove the on-board wand that rests directly behind the bag housing. After the wand has been taken out, you should see on the left side of the vacuum where the handle goes into the body of the vacuum a little gray lever (my picture this lever is yellow as I only had a Sebo X5 on the floor, but the repair is identical). This is what the lever looks like:
Step 2. As you'll see if you look closely, the lever says "closed". Turn the lever towards the front of the vacuum so the lever reads "open".
Step 3. Once the lever is moved to open, lift straight up on the entire handle assembly to remove it from the vacuum cleaner.
Step 4. Once you have the handle assembly out of the vacuum cleaner, turn the handle upside down. You'll be able to see two small metal electrical terminals that connect into the base of the vacuum where the handle meets the vacuum cleaner. Make sure that both terminals are visible. I have seen a few Sebo's where the handle has come loose, and these terminals no longer make connection to the rest of the vacuum, causing the vacuum not to turn on. You can re-attach the handle into the vacuum cleaner, turn the lever on the side from open back to closed, and test the vacuum to see if it comes on.
Step 5. If the vacuum failed to come on after reinstalling the handle, take the handle back out of the vacuum. Put one of the wires from your electrical tester into each terminal in the bottom of the handle assembly. Make sure that the tester is actually making contact with the metal terminals. It should look like this:
Step 6. With each of the electrical tester wires pushed down into the handle and making sure they are making contact, plug the cord into a standard wall outlet. If current is present, the electrical tester will light up. If not light comes on, try flipping the on/off switch and see if this has an effect on if the tester lights up or not:
As you can see in the picture above, the cord and switch on this vacuum are good. If your tester lights up when you put it into the handle, then this means that your cord and switch are good. This means that either your motor, or PC board have gone bad.
If the tester signals that you don't have any power at the bottom of the handle, then this means that either your switch or your cord is bad.
If you will please let me know the results of the electrical test here on the bottom of the handle, I will then go into the next steps of the repair, and explain how to open up the machine and either replace the cord / switch, or if you did have power here, the pc board or the motor.
Please just use the clarification request form that you used last time. I hope this was helpful in diagnosing your machine. If this helped you, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of the repair.
I look forward to helping you fix your Sebo.
Chris J.
GoVacuum
Apr 06, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
THe vacuum won't divert from hose to carpet
Turn the vacuum off, return the handle to upright locked position.
Then securely fit hose into the hose holder.
Then depress lever and engage handle into non-locked position, and turn on vacuum on "carpet"
There will always be some airflow through the hose, but when the hose is parked it creates more airflow to the carpet head
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
Water does not come out when button is pushed
Check these items:
(1) When the trigger is pulled, does the rubber pad behind the tank seal on the handle get pressed down? A rod in the upper handle presses this rubber valve to dispense water/soap.
(2) Are any hoses kinked closed at the bottom pivot point of the lower handle, where attached to base?
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
No vacuum suction during normal floor cleaning operation
That door is called a valve door, and it may have broken, part #38718013. Or the valve arm, rear broke, part number 38719048. The spring part # is 38358001. Usually it is the valve arm that breaks. You would have to take the top cover off, then you can see the parts.
Jan 27, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Problem with wheels
If the belt is over a year old, it should be replaced. This is normal maintenance and is often overlooked. When the handle is in the upright position, it will appear the the height adjustment is not working. What's actually happening is that the height adjust is easily moved so you can make any adjustment you want. When the handle is pulled back, the front of the machine will lower to that setting and lock, so it will not adjust itself while you are vacuuming. If you wish to change the setting, you have to return the handle to the upright position, or you can lift the front of the machine with your hand, taking the weight of the machine off the wheels and this will allow you to slide the adjustment to another position. It is possible that the adjustment mechanism has come apart. It is comprised of three separate components. It would be very difficult to explain it here and should be addressed by someone familiar with this model.
Jan 12, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Self propell feature not working
You can order the lever for the transmission on line for about $16.00. It comes as a cable and lever assembly. I just took the top cover off and replaced the lever without doing the cable. The reason ours broke is because we lifted the vacuum by the handle without the self propel bing turned off, this pulls on the actuator and breaks it.
Oct 28, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Kirby Ultimate G Bagged Upright Vacuum Logo
18 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
