Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Hard to start but when i do get it started and turn the choke off it will not run
  • 20 Answers
Check your fuel filter. It could be clogged. If not, it will be a problem that will require removing the carburetor and cleaning the mesh fuel strainer. It will most likely be clogged with a fine sedement. The strainer can be removed using a very sharp pointed large needle. Place the needle against the edge of the strainer and lift out. Sometimes they can be difficult but persistance is the key.That and patience.
Posted on Oct 16, 2010
Wont stay running
You should only use choke until you get a turn over. After that, turn off choke and it should start right up.
Apr 30, 2016 | Garden
My 302 Ford is catburated and is in my ranger, it starts awesome cold but when it gets hot it turns over and tries to start hard but it won't start. What is the problem?
Check your plug wires at the plug for spark. Most likely loosing spark. Could come from distributor, cap, rotor, plug wires or coil. If you no spare at the wires, see if it has spark from the coil. Please report back and we will go from there.
Apr 05, 2015 | Ford Cars & Trucks
Automatic choke problem
93 mirage doesnt have a choke, it is fuel injected! What exactly do you mean by hard to start? Does it take longer than normal to start, does it initially crank slower than normal? You could try cycling the key before attempting to start it! By this i mean, thrn the key to RUN, wait a couple seconds, turn key to off, turn back to run, wait a couple seconds,, turn to off, then attempt to start! See what that does!
Feb 14, 2014 | 1993 Mitsubishi Mirage
Hard to start how do the choke work
The choke is automatic. If the bike is having that much difficulty starting you need to have the bike serviced and the carburetor gone thru.
Sep 20, 2012 | 2001 Buell Blast
How to adjust the air/mixture screw on a 25-4cc RYOBI blower vacuum
I start with the screw about 1 1/2 turns out from fully seated (turned all the way in) but be careful when turning it all the way in not to turn it too hard as you can damage the end of the mixture screw. This should get you close enough to fine tune it.
Aug 18, 2012 | Echo Garden
Hi there i can start it up with full choke it starts it runs it clears its self i push the choke off it runs fine for about 40 seconds then its like it starts to run on 2 or 3 cilinders chokes up then dies...
check your carburatures. Sounds like they could use a tune up. Seems as if they are not getting enough fuel after it is warmed up, that is why it runs good when choked. Also check your air filter first.
Mar 29, 2011 | kawasaki ZX-9R Ninja Motorcycles
I have an aldi powercraft generator pc3200dv/10 i can start it but it cuts out after a few minutes ,i am finfding it hard to find the fuel valve also it runs for the few minues with choke on but if you...
Hi there, YES manual VERY misleading, starting it all revolves around the Choke, if I remember correctly, place lever on Choke, start then move lever to on position, good luck
Dec 30, 2010 | Electrical Supplies
Hard starting on a Makita line trimmer? How do I solve this issue?
Try pushing the primer 8-10 times hold the throttle wide open and turn choke too full.when it starts it will probably quit turn choke to halfway and start again.should stay running.If that don,t work carb needs to be rebuilt or replaced.
Nov 29, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Xr600r is hard starting when cold.
Your description makes it sound like it's running lean, not rich. A general setting for all pilot screws is one and a quarter to one and a half turns open.....not necessarily for that model. Do you turn on the choke when it's cold? Is the choke working correctly?
Aug 21, 2009 | 1986 Honda XR 600 R
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
66 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
