Question about Dell E173FP 17" LCD Monitor
Problems with my lcd screen
I am having the same problems when i turn on my monitor and it will stay on for a few seconds then shut off. i shined the flash light at it and could see the screen. i am not sure how to check the blubs can you please explain further on how to check these.
  • bella9797 May 15, 2008
    I have to turn my computer off and on for at least 4 minutes before it stays on.
I had a similar problem and I found that the power inverter board was bad. I replaced the board and now works like new.
Posted on May 22, 2008
El monitor no funciona estoy en bruselas y dell europa no se ha portado bien me tiene dando vueltas y perdiendo dinero por telefono donde puedo hacer valer mi garantia y cambiar el monitor
Posted on May 14, 2008
I was playing Fallout 3 and after a while, my screen turned a bit darker, not really dark but as if there is a light shadow on it and after a few seconds it turned black. I tried to press twice on the...
try shining a torch/flash light on the screen
If, when the flashlight is on the monitor, the problem is fixed then you have aback light issue.
You will have to contact your manufacture or shop you bought it from
Mar 04, 2011 | ViewSonic VX1940w LCD Monitor
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
My monitor will not stay on and goes black after a few seconds when I reboot it. I'll turn the monitor on and it stays on only for a few seconds but I can see all of my programs for those few seconds.
maryfoldesi1, Your monitor power supply is going into shutdown mode becauce it has detected a fault within the unit. A technician will need to evaluate it. Before doing anything visit YOUTUBE to view vid clips of "LCD monitor disassembly" and "LCD monitor repair" Also read more of my responses to other owners that have BLACK SCREEN problems and find out all your options you have open to you. You did not tell us if you can still see the Win-desktop AFTER it goes BLACK. Is it also BLANK or can you still see a faint image on lcd panel if holding a bright flashlight 1 inch from screen? lmistyrel on 12fixlouie on fixya
Dec 14, 2009 | BenQ FP731 17" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
No Image but power
find the manufature of the video card, use the old monitor and go to the video card manufacture and download the video driver.
Jun 30, 2008 | Philips 170B4MG 17" LCD Monitor
Monitor displays breifly then goes to blank screen
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Monitor blinks on then turns off after computer boots up
It could be your LCD backlight giving you problems. When the image "goes off" shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 20, 2007 | Hyundai L72S-8 17" LCD Monitor
Problem LCD screen stays white bright after switch button is OFF ??
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
May 12, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Dell E173FP 17" LCD Monitor Logo
88 people viewed this question
Alun Cox
