Question about Dell Dimension 2400 PC Desktop
Won't read dvd
I changed hard drive, added memory and a new video card. My friend took my old hard drive to retrive the info and put it on a dvd. It now won't reconize the dvd or any dvd I put in. I changed cables uninstaled and re-started cd/dvd,but a message "insert disk in drive" whenever you put one in. It still plays and rips cd but the sound quality seems to have suffered and it just started when I changed the hardware. I have installed windows media 11 and all drivers. I know this isn't an easy one
Thanks
    Genius:
  • 3,587 Answers
I'd say that this is caused by whatever program was used to do the DVD backup..you'll need same program, to most likely unencrypt that data, no?
Posted on May 07, 2008
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
Im having a problem with my Micro SD 4gb Memory card for my Samsung Intensity phone. I put it in my computer & it read just fine then I took it out & put it back in when the file for it wasnt...
simple rule....when a device / drive is reading a media (say CD disk, pen drive, memory card etc) never pull it out....
it spoils the media....
frequent changes to any media device will hamper it's quality and efficiency.....
the recent micro cards are so sensitive that even a small mis handling / hard handling will make it corrupt.....
the best option...buy another one...
reg
Suresh
Apr 28, 2011 | Computers & Internet
I resently installed a Samsung DVD-ROM SD-608 into a friends machine. My problem is that the new drive reads CDs but not DVDs. In MY Computer it also shows it ad CD Drive and not a DVD Drive. Do I need new...
old dvd rom can not read the new dvd disk only the reson software.
sorry to tell,you should change the dvd rw newly instead of old
Hope it will help you.
shibuda
Nov 24, 2010 | Samsung SD 608 (SD-608) Internal DVD Drive
Detecting dvd drive. biostar P4M900-M7 SE One day i smashed my pc , coz of a blue screen, stating bump in phyiscal memory. HAD IT FOR 2+ YEARS. And maybe i still have it, but anyway, i took it all apart,...
Hi Tom,
I suggest that you use the one marked IDE1, unless you have your hard drive on that port. I assume it's one of the sata's. But, make sure that your DVD drive has it's pin's set right. If it's going to be the only DVD drive on the machine, and your hard drive is a sata, then make that DVD drive the master pin set, if your Hard drive is a ide drive, then make sure that your hard drive is set to master and then your dvd will be set to slace. If you place the hard drive on the white slot, and the dvd drive on the green or colored slot, then you can choose cable select on both drives. But when you make it Master and Slave it doesn't matter which IDE you use, the pin tell the computer what is what.
Good Luck,
mark
Nov 10, 2009 | Biostar P4M900-M7 SE Motherboard
I had a Nokia Music Xpress phone on a t-Mobile plan. I took the mini SD Cars and put it in my new phone the LG Xenon, which is an AT&T phone but unlocked for T-mobile. I am trying to get the info off...
It wont. A memory card cant be switched from phone to phone. I had to put my memory card back in my old phone & put all the info (music & pics) onto my computer in a file. Then put the memory card into your new phone & go to that phones settings and it should ask you to format the card for that specific phone(which means ERASE) so a memory card cant back & forth keeping same info & reading info on different phones. So the only way to save your info is put in a file on comp then let your new phone reformat it so it can work then hook that phone up to your computer & put all the info BACK on there.
Jul 17, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Which specific harddrive components would you put into a home-assembled PC?
DUE you're going to work with graphics files you need a good HDD (capacity) 500 GB will be great
Memory at least 1GB and above
Processor 3.0 Ghhz and above
DVD Drive (any double layer)
Sound card (on board is enough), however you can improve later adding a new one, but you don't need that)
Good Graphics card (At least 256 MB)
Oct 07, 2008 | Computers & Internet
Mitsuba DV9002
I have a cd for the driver for this camcorder, but it does not work. Where can I get the drivers from. I also cannot save to the DVD HElp!!!!!
Aug 18, 2008 | Mitsuba DV9002 Flash Media Camcorder
Computer video went out while in the middle of something. Tried to restart- hard drive makes proper sounds but still no signal. Checked to make sure all cables were still in, turned monitor on and off....
pull out the memory modules and power up the pc. It should make a series of beeping sound, indicating the motherboard as operational, and it could be a case of defective memory. Otherwise, I would say the board is defective.
Jul 17, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
47 people viewed this question
Alun Cox
