Question about Black & Decker String Trimmer Cordless 12" 18V
Black & Decker Grass Hog Electric Trimmer
The automatic feed for the trimmer line is no longer working. I have replaced the trimmer spool with a new B & D spool ( I was replacing my own line) but the auto feed still does not work. Please advise. Thanks
  • 11 more comments
  • Stephanni Taylor
    Stephanni Taylor May 14, 2008
    Having the same problem with mine, so far I cannot find a solution.
  • popish May 23, 2008
    Sometimes it works and sometimes it doesn't. When I press the button the spool rotates and cuts grass for about 10 seconds then stops. checked all connections, even took it apart and found no loose wires.
  • Linefeeder Jun 10, 2008
    Thanks hammer drill! I bought a new lever release for the spool and I'm no longer manually feeding line.
  • jmitton Jul 05, 2008
    My auto feed no no longer works. I went so far as to buy a new trimmer which worked well for a while but now has the same problem.
  • mompy Jul 27, 2008
    Where do you buy the lever release??
  • wfhenderson Aug 03, 2008
    I have exactly the opposite problem. Mine will not stop feedling line. I have disassembled the head and it is clean inside and the white arm moves freely, When turning the spool by hand the cogs seem to lock in place and the spool turns in unison with the shaft. But as soon as I apply power, it begins feeding and cutting its line without stop.
  • Anonymous Aug 29, 2008
    The machine overheats the line actually melt together and won't automatic feed. This is my second one with the same problem
  • Anonymous Aug 30, 2008
    what hold the reel in side
  • Anonymous Apr 11, 2009
    automatic feed does not work
  • Anonymous Apr 12, 2009
    Same same. Line feed is inconsistant. Very annoying and unproductive.
  • Ken Smith Jul 27, 2013
    Mine over feeds line and I have check the connections. It is very costly to use these spools!
  • Nina Ward
    Nina Ward Nov 09, 2013
    same problem. I've tried everything. Very Frustrating.
  • Anonymous Mar 21, 2014
    have tried replacing spool, cleaning inside, etc etc
  • 3 Answers
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
    Problem Solver:
  • 18 Answers
I had this problem too, but it had nothing to do with the white lever. I finally found the solution in a clue about the line. Black & Decker line on the pre-wound spools is silicone lubricated. I tried spraying my line with WD-40, but that didn't help.
Here's what works: Talcum powder.
You can get it anywhere, usually labeled as baby powder, but make sure that it is talc, not corn starch baby powder.
I spread the sides of the bulk spool enough to shake the power in, maybe two teaspoons or less around the coiled line, then put it in a zipper plastic bag and shook ti to thoroughly coat the line.
Before loading the B&D spool, I rubbed a little more talc inside it, then wound the line.
It worked flawlessly!
Posted on Aug 20, 2008
    Champion:
  • 313 Answers
The problem is the white lever may be broken. its located at the bakc of the spool line,
Posted on Jun 01, 2008
  • Toni Rust May 31, 2013
    The white lever in mine is broken too! Where can you get one to replace it and does that make the line feed constantly when it is broken?
  • Brandon
    Brandon Apr 01, 2014
    yes it can. there are tons of online vendors simply search for your model number replacement parts.
Yes! the previous answer is the correct one! I had generic silicone spray which did the job quite nicely.
Posted on Sep 29, 2011
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
Jun 14, 2015 | Black & Decker Black and Decker & Grass...
The nylon thread has worn down. How do I get more of it to come off the spool which is still full?
Hi cmlontg152...
You will have the grass hog running and then bump the turning head on the ground and it will automatically feed out the line, the more you bump it on the ground the longer the line will be...don't make it too long at a time...only what you need.
Please take time to rate me
Jul 08, 2011 | Black & Decker 14" Grass Hog Xp...
Black and Decker electric trimmer (grass hog) model GH600...eats thru line, one spool lasts about 3 minutes
It sounds like that the automatic line release is damaged.
1. Remove and clean all debris from the head. I assume that you have already done this if you have changed the line a few times, but just make sure.
2. Remove the the head from the shaft.
3. There should be a large spring in there. If its broken, damaged or missing that will allow the head to spool line pretty fast. again make sure all debris is removed from this area.
4. Check the feed dogs in the same area as the spring. If they are worn the same problem will occur.
5. Install line on the spool.Make sure that it is wound the proper direction. There should be arrows indicating this. The line wound in reverse will also cause the same problem as well.
6. Put it all back together and see if works now.
7. If this doesn't solve it you may need to replace the head assembly.
Jul 02, 2011 | Black & Decker Black and Decker & Grass...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
B & D trimmer feeding too much line
Do you remember putting the spring back in when you filled it with new line. You mite check to see that it is in there.
Good luck
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Black & Decker String Trimmer Cordless 12" 18V Logo
2,614 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
