Question about Konus hot Rifle Scope 7234 Matte 3-9x32
I had a gunsmith install my Konus #7234 3x9x32 and the instructions were not forwarded. Q. As I look down the scope at the target, the adjustment labeled left (with arrow) is that oriented like my left as I face the target?
    President:
  • 2,702 Answers
Yes it should be,,,to zero your scope clamp your rifle down so it wont move and fire into a target look at the hole the bullet made and if the cross is not on it move the cross till it is over the hole,,,dont move the gun till you have lined up the cross with the bullet strike,,,,,you should zero it in 3 shots this way?
Posted on Aug 30, 2010
Windage and elevation adjustment won't move on konus 275 scope
you may have run out of clicks or the adjustment internals are damaged
Nov 02, 2013 | Konuspro 275 Muzzleloading Riflescope...
The reticle on my konus pro 4 x 32 does not move when i adjust it
Are you trying to see the reticule move? Or are you shooting after moving the adj screws??? You won't see the reticule move, It only moves maybe 1/4 inch max both ways, If you have a bolt gun, mount the rifle in a vice or a cardboard box with v's cut in it to hold the rifle, aim at a given target app 100 yards away, then sight down the bore, you should be able to see the target, if not, line up the bore, then adj the scope to it, you will be on paper at 100 yards, Try it.,,,,, also, the cross hairs are mounted in a tube that is adjustable, the wires themselves are fixed.
Apr 17, 2012 | KONUSPRO 4X32 MBLK KON7262
What size is the battery for the red dot target scope please?
Every red dot finder uses a different size battery. If you do not have the old one call Optics Planet, they sell these scopes. Usually they take a small watch style battery.
http://www.opticsplanet.net/?gclid=CIX31Y-2o6sCFcY32godbnEB5Q
Sep 09, 2011 | Konusmotor 500 (230 x 114mm) Telescope
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
How to fix jammed clicker on air rifle scope
Sorry to tell you but the crosshair adjustment is more than likely broken. Take it to a qualified gunsmith and he can check it out for you.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks.
Jan 12, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Simmons aetec, put on muzzleloader to boresight and adjustments work in reverse.
It's a common misconception to think that you're moving the bullet impact on target, when in fact you're moving the scope's reticle to look where the rifle is shooting.... So if your shooting left of your target.. you want to move the crosshairs to the right.
Hope this helps, mark the Gunsmith
Please leave feedback, Thanks!
Jan 09, 2010 | Optics
Which knob on the bushnell banner scope will raise the bullet when it is hitting six inches low?
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that same spot.
To move the scope's reticle up or down, turn the adjustment on the TOP of the cope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
Dec 13, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Sight adjustments
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that very same spot.
To move the scope's reticle up or down, turn the elevation adjustment on the TOP of the scope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
If you want to move the direction the scope is looking left or right, turn the windage adjustment on the RIGHT side of the scope left or right to look where the bullet is impacting. To move the crosshairs to the right, turn it right.
Dec 11, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
The reticle adjustment knob is turned all the way out (counter clockwise) and still hasn't moved the point of impact to the right enough.
If you have Leupold/redfield style windage adjustable baes you just need to move the windage adjustments. If you don't have these, I would recommend you take your rifle to a qualified gunsmith and have him remount and boresight your scope with this style scope base(s) which should run you about $80.00
hope this helps, Mark the Gunsmith
Oct 22, 2009 | Optics
Can a novice install a Redfield base and rings?
Problem solved. Redfield had all the size information I needed and mounting the base was a breeze.
Jan 17, 2009 | Redfield See Thru Rifle Scope Mount Base...
Konus hot Rifle Scope 7234 Matte 3-9x32 Logo
174 people viewed this question
Top Konus Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Geoff White
Geoff White
Are you a Konus Optic Expert? Answer questions, earn points and help others
