Question about Kitchen Ranges
My oven quit working, I can smell gas and the glow rod (not sure if thats the right name), is heating up, but not igniting the gas. At one point it would light, but go out after a few minutes.
  • Kitchen Ranges Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Aug 29, 2010
The oven does not heat up to full temperature and often smells of gas
This sounds like your oven igniter is getting old. if it glows but is orange in color it is getting old. They should glow a bright yellow. Check your model number to get the correct part
Nov 26, 2012 | Kitchen Ranges
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Ignitor glows but burner doen't ignite. Don't hear any gas flow or smell any gas.
heatman101
Jul 26, 2011 | Ovens
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Oven won't stay heated, clicking noise like its trying to ignite, and gas smell.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Ovens
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 29, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kitchen Ranges Logo
114 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
