Question about Mitsubishi WS-55807 TV
TV won"t stay on turns off in 3 seconds WS 55807
  • c21pacesette Aug 29, 2010
    it blinks twice for 10 ten times
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 29, 2010
  • 3 more comments
  • SD Tech
    SD Tech Aug 29, 2010
    Unplug set for a few minutes. Plug back in and turn on, green light goes on then goes off--do the self check, it will not repeat error code more than about 5 times, let me know error code found.
    You have to watch closely.
    error code repeated 10 times
  • waterdog1969 Feb 12, 2011
    what does the error code 2 blinks, 2 blinks mean? My Mitsubishi was working just fine, never any problems, and my son turned on his PS3 and all of a sudden it turned off. I did the test and it gave me the 2 blinks
  • SD Tech
    SD Tech Feb 12, 2011
    it is short protection, do you have Yahoo IM?
    yes
SOURCE:
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
Tv will not stay turned on
its a problem in your main board of the tv.
Oct 30, 2008 | Mitsubishi WS-55807 TV
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 turns on but then powers back down after a few seconds
Good Day;
The fuses tell you that circuit has failed and was drawing too much current. No other test is needed.
Good Luck, big Irish.
Sep 04, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WS-55807 power up problem
If you are handy with a multimeter you can check all of the pico fuses the little green 5 amp fuses. Most likley you will find one of those shorted F95A01 most likley but could be another. You will need to change this and also your convergence amps. These three parts are most likely shorted in your set. You are looking at about 250-350 from a competent repair shop.
Feb 04, 2008 | Mitsubishi WS-55807 TV
Turn on tv and after a minute it turns itself off
Check fuses F9A04 and F9A05 (5A micro fuse)on the board in the middle.If one or both are open than you need to change both the convergence IC's (STK392-570)along with the fuses.
Aug 21, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
618 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
