Question about Car Audio & Video
Reset the radio after changing battery - Car Audio & Video
  • 4,861 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you require a code for the radio
Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing
Posted on Aug 29, 2010
Need the radio code to reset after battery was disconnected.
Afraid there is no radio code as such....the Saab headunit is paired to the car with Saab Tech 2 software.
A dead battery swap shouldnt lose the radio if it was working before you changed the battery.
Have you checked the fuse for the radio?
You should also post on Saabcentral
Jan 14, 2016 | Saab 95 Cars & Trucks
Radio will not power up.
there is it should be located on the back of radio itself. if that doesn't work you may need to check your fuses
Aug 19, 2013 | 2005 Subaru Forester 2.5
After changing 12 volt battery, how do i reset radio?
I just changed battery in my boat and had lights and static on my radio. I removed front cover and pushed reset button. Now I have no lights sound or even static.What next?
Jun 13, 2012 | 2004 Toyota Prius
Change battery on my 2004 honda CRV 2wd i need a code to reset radio
The code is usually on a sticker on the side of your radio or the side of the glove box. sOME TIMES THEY WILL PUT ONE OF THE STICKERS IN YOUR OWNERS MANUAL ALSO
Good Luck
Apr 10, 2012 | 2004 Honda CR-V
I tried too many codes to reset the radio after changing the battery and now I cannot put the right code in. It just says Code Error. How do I reset the radio? Do I have to disconnect the battery to reset...
The normal method to reset a radio after wrong codes have been entered is to LEAVE SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itsel
This could take several hours.
Further useful information can be found here
Sep 26, 2010 | Car Audio & Video
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
Reset code for 2006 nissan maxima radio
just changed battery,,all good,,radio is out,,tried fuses ,, what can i do to get the radio back on...
May 19, 2010 | 2006 Nissan Altima
Changed battery on 05 nissan pathfinder. vdc
try and disconnect the pos battery cable for a bout 10 minutes and see if this resets it make sure you have radio code in case ur radio locks
Feb 21, 2010 | 2005 Nissan Pathfinder
Reset delco antitheft car radio
try hitting the reset button that is behind the faceplate.
Dec 14, 2007 | Car Audio & Video
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
