Question about Sharp LC-32D6U 32 in. LCD Television
My speaker bar does not seam to be working right. I had sound, then it was gone. after a couple of days had sound again. Now I have no sound
  • 11,361 Answers
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find. You may be better off if the sound does work through the PC speakers, to get the TV repaired; it will be more than $100 and up.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 29, 2010
PROTRON 26 INCH TV SOUND BAR
On some TVs, you have to turn off internal speakers to direct sound to external audio connectors.
Sep 29, 2017 | Protron PLTV-26 26 in. HD-Ready LCD...
The sound just plain quit. The it came back one time and then it quit again. I installed a Serif tool bar and the the sound went out shortly after that. I tried to completely uninstall the Serif bar and...
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Nov 08, 2012 | HP Pavilion DV6500Z Notebook
No sound device detected
I'm going to give you a couple of ways to check this;
1 Click on "start" then, click on "control panel". In your list (icons), find "device manager", right click on , open and click on continue. Click on the box with + next to "sound audio and game controllers". You should have a drop down of your device, probably HD audio. Right click on that. You should see "disable" in the list. If you see "enable" click on that and exit. Right click on it again and click on the "properties" tab. You should see "this device is working properly. Windows adds generic or genuine drivers taht usually work for Realtek (ALC662) so, if you want to try an update, right click on device, then click on "drivers" tab. Click on search web/internet for drivers...
You can check by clicking on the speaker icon in your taskbar at lower right of screen. Right click on it. Click on playback devices. You should see a green check on left and sound bars on right. Right ckick on your device and you should see "disable" if you see "enable" click on that, exit.
right click on again and click on "open sound mixer" and adjust volume. Right click on the speaker one more time and right click on your device. Click on test. the bars should respond and you should hear the pings.
Mar 30, 2011 | Asrock N68S Ucc Socket AM2+ GeForce 7025...
Right loudspeaker problem
Doesnt sound like the selector as it "sometimes" works. Redo the speaker connections on the back of the amp and speakers first. If it persists, swop the speakers and cables, if the problem swops, then it could be inside the speaker or the cable, if still the same then amp has dry joints/loose connections probably
Jun 24, 2009 | NAD C372 Amplifier
Logitech Z4 sound from one side only
Reconnect all the wirings in your speaker set. Be sure you connect all the cords properly.
May 25, 2009 | Logitech Z-4 Computer Speakers
Speakers don't work
Have you tried right clicking on the speaker icon in the task bar or gone to my computer and looked into the sound settings and make sure your speakers are not set to MUTE?
Apr 10, 2009 | HP EliteBook 6930p Notebook PC
Distorted sound (voices sound like "Alvin and the Chipmunks"
Have you tried another set of speakers? If not I would do so cause your speakers might have just gone bad!
Mar 22, 2009 | HP Pavilion a1730n PC Desktop
Bike wont idle and power constantly dieing and recovering
check to see if you have gas in the oil from a carb leaking down which will cause the idle speed to drop when motor warms up.pick up idle run for awhile then plugs foul.like you said a carby problem.
Feb 16, 2009 | 2006 Honda CBF 250
My right speaker from my z-2300 stop working.
sounds like a loose connection somewhere inside that particular speaker. You could open it up to check for a loose or separated solder joint. The safe option would be to return to place of purchase and exchange for a new set.
Apr 14, 2008 | Logitech Z-2300 Computer Speakers
No audio coming from my receiver
my speakers call creative on my computer wont work they use to,i hear sound but not audible
Aug 12, 2007 | Onkyo TX-NR1000 Receiver
Sharp LC-32D6U 32 in. LCD Television Logo
103 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
