Question about Polaroid 4241-TLXB 42 in. LCD Television
The tv screen is dark on the left side, the right side is fine. The images are still visable, but it's a dark orange, lingering image. The whole half of the screen is dark, but one part towards the far left is lighter and one part towards the mid-left is darker. The tv will flicker from regular to dark just on the left side before it goes dark. Sometimes the entire screen will flicker from this dark orange and then will go dark orange, but with streaks of white vertical lines when any images with high contrast show up. When the whole screen is dark, it is much more difficult to see any images and the images are much more lingering, like a tracer effect, but then the entire screen will flicker from the extremely diffecult to see lingering images and white streaks to a more nutral state of darkness, which is the same state when just the left side is dark. I used to be able to turn off the tv then back on again,when it was in this full screen more nutral state, and it would be fine but not any more. Any help would be appreciated. Thank you.
  • 70 Answers
SOURCE: "melting" screen image
the problem is the backlight not lit evenly.
have the backlight inverter board checked for correct ac ht and if that is okay then u will have to replace the backlight.
Posted on Jul 11, 2008
circuitworld
  • 335 Answers
SOURCE: TV Powers up and is Backlit, Displays color
Your Timing control board is defective and needs to be replaced........
Posted on Nov 03, 2009
  • 9 Answers
SOURCE: i have a polaroid flat sreen tv and on the left
Try replacing the (T-conn) logic control board. It is behind the control box top middle.You can find them on ebay, shopjimmy or discount merchant.com
Posted on Dec 11, 2009
maatmartin7
  • 1229 Answers
SOURCE: I have a Polaroid 40"
I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
Posted on Sep 19, 2010
SOURCE: Last night I turned my Polaroid TLX 04244B off,
When I relocated to Peensylvania, I have lost the "TLX-04244B" powercable and remote Control somewhere. I tried another Cable(My Desktop compuetrs powercord) and the TV powered on but most of the times it has white horizontal lines in the screen. After few try it will become stable. Is this incorrect powercable is causing the white horizontal lines. If so where can I get a replacement Powercable. Please advice. thanks Rgeorge.
Posted on Aug 20, 2011
LG 55 UF6450 tv. The left half of the screen went to a weirdly shaded image over about 15 minutes and stayed that way.
The left side data buffer board is damaged, in most case is water leaked to the left side of the bottom screen.
Jan 12, 2018 | LG Televison & Video
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Dlp tv hl-r5688w samsung
i believe the buld is bad replace it its cost from 200 to 500 dollars depending on the year and model
Jun 20, 2008 | Samsung Televison & Video
WS-55807: Images are dark on right side of display, but will go away after 3-4 hours.
you could be on the right track get some freeze spray and go around all the parts to see if you can make it act up, same with heatgun or hair dryer when first turned on heat one area at a time to narrow your problem down
Oct 21, 2007 | Mitsubishi WS-55807 TV
Polaroid 4241-TLXB 42 in. LCD Television Logo
156 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
