WD62725 RED LIGHT ON AFTER NEW LAMP INSTALL FAN DOES RUN
  • worldcatbob Aug 29, 2010
    switch is working lamp is philips
  • 10,594 Answers
Make sure lamp cover is fixed in its position securely after lamp replacement. It is first thing that you removed from tv cabinet to replace lamp and it is necessary to put it back properly because lamp cover has to press a safety micro switch inside cabinet.
Let me know replacement lamp is Mitsubishi original lamp or any low price bulb?
Thanks.
Posted on Aug 28, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Aug 29, 2010
    OK, and what is title of red light on tv front? I mean is it power, lamp or temp light.
    Is it blinking or just solid?
    it is not blinking lamp light
    Solid lamp light means Lamp did not turn On and reason could be defective lamp.
    If you replaced bulb in old lamp housing then recheck its connections wires and if wires are OK then make sure lamp is inserted fully in its box in tv.
    Thanks
    low cost bulb can also refuse to turn On so I would recommend to have Mitsubishi original lamp that comes in lamp housing as replacement lamp.
Phillps tv model number 50pl9126d/37 what is the red light mean
It depends on whether you are able to see a clear image or not. check the lamp first if its more than 2 yrs old you may need a new one, last one we checked with the problem you describe had a fan running slow. The fan nearest the lamp needs to run correctly or the tv will shut down. Good luck !
Nov 11, 2011 | Philips 50PL9126D/37B 50" DLP TV
Nec lt81 dlp projector
PLEASE SEE THE SPECS OF OLD LAMP AND NEW ONCE ARE THE SAME IF YES TRY CHECK THE POWER SUPPLY AND RATING OF THE SUPPLY. AND RESET SWITCH WITH REMOTE CONTROL
Feb 24, 2008 | NEC MultiSync MT1050 Multimedia Projector
3m-X50 Lamp will not light up. Changed lamp.
you have a bad ballast. you'll have to replace it.
Aug 17, 2009 | 3M X50 Multimedia Projector
New lamp won't light
I am having the same problem now. I am currently trying to reset the timer...but have yet to successfully. But I do think this is the solution.
Jun 10, 2009 | Sharp DT-100 Multimedia Projector
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Red Lamp Light turns on
Red Lamp light shows that TV requires New Lamp.
Please always buy original Sony lamp for smooth run of TV.
Mar 15, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Mitsubishi DLP - model #WD62725
We're under a service plan and had the guy out today. Same symptoms. He replaced the lamp and it didn't work and then called Mitsubishi. They said it is probably a very common capacitor problem on the power supply board. If you open the back and take a look you are likely to see bulging caps. Parts C9A37 and C9A38. The caps are cheap if you can find them, but the parts are really hard to find right now so Best Buy is actually replacing these for people under service plans rather than fixing them. You probably ignored the "warning signs" like we did and didn't think much of it when the TV said there was something blocking the air flow and the lamp was going to shut off. We now know this is a sign that the caps are getting too hot and need to shut down to cool off... Good luck! BTW, our guy said the repair will run you about $200 if you can't do it yourself.
Aug 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
WD62725 Lamp
code 34 is lamp abnormlality which what you are discribing is most likly the balast, since the lamp comes on for a brief second then shuts down. the part # 939P978010
Jan 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
