Question about Vacuums
I was changing a light bulb with one of those metal extension rods that unscrew and screw back in the replacement bulbs. It evidently didn't seat correctly and pulled off the bulb and created a quick "poof" type electrical short. I have switched out that bad bulb with a new one and can't get either the fan or lights to work. There doesn't appear to be a reset switch. I also swirched out the wall switch to see if that would make a difference and it does not. Any thoughts or ideas would be appreciated. Bobby
  • 377 Answers
If you have not already done so, I would check at the fuse or circuit breaker panel to see if you have blown a fuse or tripped a breaker.
Posted on Aug 29, 2010
Replace headlight bulb
Usually there is a small Phillips screw under the plastic lamp cover. Remove that, remove the cover and unscrew the bulb. Replace the cover and the screw.
Some covers may have a slot or two slots and you need a slim screwdriver in each slot to push back some locking tabs to release the cover. Don't push too hard or they might snap off.
Aug 13, 2014 | Electrolux Vacuums
How do we get the plastic cover off the machine? We have removed all visible screws on cover and plate, removed cover over light bulb area, and plastic extension around plate area. We are trying to...
Is this a sewing machine? Plastic covers can be tricky to remove. Look for deeply set screws in deep holes, as well as screws that might become visible after removing covers. Sometimes the screws holding the rubber feet on will also secure the cover.
Aug 20, 2011 | Vacuums
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Mar 11, 2011 | Electrolux Epic 3500 Vacuum
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
How do I change the belt on Eureka Pet Pal
Unlike most vacuums, this one the screws are on the top of your base. There are two screws one on each side. When looking at the front of the vacuum right side screw is located above the s in 12amps and on the left side screw is located above the p in pet. Now keep in mind it's not directly above the letters look about 2 inches up. Unscrew them, take cover off. Once you have done that pull up on the brush rod. Maybe tough if ur vacuum has a lot of built up dirt. Next put belt on metal prong then put on brush rod. Place rod back in its spot, gonna need little bit of muscle. Then put top back on and replace screws. Plug in flip bottom just to make sure brush is spinning. If u have followed steps this should work. I hope this helped took me forever to find the screws because I have always had vacuum with them on the bottom and internet was no help to me. Good luck
Nov 25, 2010 | Eureka 3276AZ Pet Lover Bagless Upright...
How replace lightbulb on carpet beater (Electrolux central vac). Can't find any screws near light
To replace the bulb you will have to remove the power nozzle cover. Remove the cover by extracting the screws from the bottom. Take notice of which screw comes from which hole. Depending on the year, one screw may be shorter than the others. If put back in the wrong place, the screw will come through the cover when replaced. Once the cover is removed it's easy to replace the bulb. Make sure everything is lined up when reassembling.
Dec 30, 2009 | Electrolux Centralux Vacuum
How do I get the cover off my Kenmore PowerMate canister vacuum? The roller is stuck.
Remove the top that covers your light bulb, remove the two screws, unscrew light bulb, flip unit over and find the two clips on the right and left side, gently press each clip and the hood comes off
Aug 24, 2009 | Vacuums
I have a Fantom Fury, and I cannot get the cover off of the motor assembly. Do you have any drawings or schematics that would help me accomplish this?
first need to open two light bulb covers with a screw drive and you will see two small screws. Remove the light bulbs and unscrew two small screws. After that, you can move the cover off.
Dec 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Change light bulb
ok just like you would change the belt take screws out of top the cover should come off inside there is a plastic cover take it off theres the bulb
Jun 29, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
