Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven is not getting hot only warm - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • 28 Answers
You may have a failed bake element, and the reason why the oven is only getting warm is the Broil element is cycling only. You may be able to remove the element and ask your local parts store to test it for continuity.
Posted on Aug 29, 2010
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Oven not getting hot
I would recommend checking the circuit breakers, assuming that there is a 230 volt supply for the heater elements. If that is OK you might have a bad heater element.
Jan 13, 2012 | Frigidaire Ovens
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
Aug 11, 2011 | Zanussi ZHQ575 Electric Double Oven
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
I have a Kenmore 9114012190 oven it does not heat properly anymore the top and lower elements get hot but it will hardly get anything warm that is placed in it ie; bread has to stay in it for 45 mins to...
start by checking your input power for a full 240volts,then check the terminal block for any burned off power input wires,then check power connections all the way thru the oven control and finally check for "hot-spots" in both elements(highly unlikely that both would be bad) its a discolored area that is a high resistance area not passing full operating power thru element(s)
Nov 19, 2009 | Kenmore 40192 / 40199 Electric Single Oven
Oven getting warm but not hot?
If it is an electric fan assisted oven, and the fan is working o/k, \then you need to fit a new oven element., usually located at rear of oven compartment.
Please rate my solution.
Thanks.
Nov 16, 2009 | Smeg Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
174 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
