Question about Kitchen Ranges
Our new maytag gas double oven 750 series - ignitors started ticking all 5 at the sametime and won't stop.
  • jameswissmil Nov 19, 2008
    all 5 ignitors won'stop sparking.We have a jenn aire dual fuel range. What gives?
  • 552 Answers
It sounds like a stuck button or switch.
Posted on May 07, 2008
I have a maytag gemini double gas oven and the bottom will not heat up. modle # MGR6775ADW. what might cause this?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 26, 2011 | Maytag MGR6775A Gas Kitchen Range
IGNITER GLOWS BUT NO GAS GETS TO THE BURNER. WHILE IGNITER IS GLOWING, THERE IS NO VOLTAGE ACCROSS SAFETY VALVE TERMINALS. SAFETY VALVE RESISTANCE IS 2.2 OHMS. NEW IGNITER MAKES NO DIFFERENCE. Model:...
Hello John,
Having replaced the ignitor and the gas valve having continuity the problem has be the gas safety valve bimetal is stuck. The only thing you check is amprage draw on ignitor it should be between 3.2-3.6 (as label on gas valve states) with a new ignitor and again continuty on gas valve its the gas valve its stuck and wont open.
Good luck,
Gene
Aug 09, 2011 | Maytag 27" Built-In Double Electric Wall...
Maytag oven model mgr5770 oven hard to light and doesnt keep temp even when it does gas stops lighter still glows?
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps
Gene
Aug 01, 2011 | Maytag Kitchen Ranges
My built in oven igniter comes on but gas does not
Believe it or not the problem is with the ignitor. This tip will help to explain it more fully.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Jan 24, 2010 | Maytag 30" Built-In Double Electric Wall...
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
I have a Maytag Gemini Precision touch 750 series double oven range MGR6775ADB. The lower over is not responding. It will not preheat. The display says preheat and stays at 100. There is no flame igniting.
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Sep 30, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven does not light up when turning on.
those ignitors have to draw between 3.2 to 3.5 amps if only 2.9 will still glow but not enough.that said,has any one cleaned latley and shut the supply valve to the oven safty valve by accident.ive had that one before too.if not need new ignitor.In Gods service,tom
Jan 02, 2009 | Maytag Ovens
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
