Question about Whirlpool Calypso GVW9959K Top Load Washer
Flashes 44 on front panel. wont start up - Whirlpool Calypso GVW9959K Top Load Washer
  • 3 more comments
  • rubas2633 Aug 29, 2010
    there wasnt a wash cycle going. it just lights up 44 along with the normal cycle led and couple others. also beeps about every 20-30 sec.
    whirlpool calypso washer model GVW9959 flashes 44 and beeeps every 20-30 sec. wont start up or allow me to clear error. the normal cycle light lit up along with couple other lights.
    why replace the lid? there was no wash cycle running. is there a switch that can be replaced on the lid?
    which part of the lid?
    blowing air did not work. no electronic components on the lid.. could control board be bad?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the lid opens while the unit is in running mode, time remaining will flash in the display. Close the lid and press START to continue with the cycle. If still the issue is not resolved then you’ll have to replace the lid. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
  • Rylee Smith
    Rylee Smith Aug 29, 2010
    Before replacing the lid you can also blow air on it with the help of hair dryer and see if it works.
  • Rylee Smith
    Please click on this link and download its service/repair manual which will tell you what needs to be done and how to check the lid switch. Please
    assistance.
    Thanks
    Rylee
  • Whirlpool Master
  • 8,220 Answers
If the lid opens while the unit is washing the time remaining will flash on the display Close lid and press start.
Service Manual
Car will do nothing. as if the battery wasnt hooked up. has new battery. no lights. NOTHING
2001 Buick Lesabre: Car Will Not Start Does Nothing Took ...
www.2carpros.com/questions/buick-lesabre-2001-buick-lesabre
Apr 22, 2007 - Car will not start does nothing took battery out to get tested because it would not jump start battery found to be good put battery back in ...
how to fix a buick century that wont crank - YouTube
? 2:44
https://www.youtube.com/watch?v=UWfvEouMMtc
Dec 18, 2009 - Uploaded by jay eltatertoto
how to fix a buick century that wont crank. jay eltatertoto ... How to easily fix a Buick that will not crank and security light flashing - Duration: 6:06. ... My Car Wont Turn Over - How To Test The Starter / NSS / Ignition Switch - Duration: 5:21. ... 2001 BuickCentury Custom - Duration: 19:44. uxwbill 19,621 views.
Car Won't Start Because of Anti-Theft System That Uses ...
repairpal.com > Problems > Buick > LeSabre
Feb 05, 2016 | 2001 Buick LeSabre
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
No sound no picture
Dose the lamp light indicator in front panel flashes?Than lamp must change.
Mar 16, 2010 | Panasonic PT-52LCX65 44" HDTV
Red light flashing.set will not start up.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
LG RE-44SZ21RD 44 whihc doesn't start
i think you'll find the lamp needs replacing
May 15, 2008 | LG RE-44SZ21RD 44" Analog Television
Wd52525
>>The first thing to do is a system reset using the recessed button on the front panel.
>>If that does not work, unplug the set and let it sit overnight
SYSTEM RESET button with a pointed item like the end point of a paperclip
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
