Question about Canon i9900 InkJet Photo Printer
The printhead moves and it sounds loke it is printing but the paper is blank?
    Brigadier General:
  • 10,406 Answers
A few possibilities:
1. out of ink -- replace the ink-cartridge
2. clogged ink-jets -- run the "print-head-cleaning" utility.
3. messed-up electronics inside the printer -- buy a new printer.
Posted on Aug 29, 2010
Texas instruments printer PN 2222738 serial #59400 any parts available
Hello friend,
Does the Printer SOUND like it it is trying to print but leaves paper blank ? . If so could be an inking problem.
are you in USA ? Well heads are available here http://www.ebay.com/itm/TEXAS-INSTRUMENTS-TI-880-885-895-PRINTHEAD-2222738-0204-V6-WARRANTY-PRINT-HEAD-/161306476717?pt=US_Print_Heads&hash=item258e9d80ad
Aug 25, 2014 | Office Equipment & Supplies
My print comes out with a blank strip down the left side of page......when print out comes out about a fourth of the way from left to right theres a blank strip fromtop to bottom...about a inch wide
If the printhead in an inkjet printer is printer but not moving then a single block of print will normally be generated along the page. When this kind of problem happens the related components include the printhead positioning motor, the timing belt, the home position sensor, the control board and possibly the power supply.
With the power off, manually move the printhead to the center of the printer. Turn the printer on to see if the printerhead seeks the home position at the far end of the printer. if the printhead moves to the end of the printer, and it doesn't turn off, or doesn't return to the center of the printer then the home position sensor is malfunctioning and needs replacing. If the printhead assembly will not move at any time, check to see if the printer is in maintenance mode. In this mode the printer typically keeps the printer assembly in the home position. If no mode problems are present, then the positioning motor should be replaced.
Good Luck!
Dec 13, 2010 | Lexmark X2600 InkJet Printer
Blank paper comes out when print is pressed
Can you hear the print head moving??
If so then ink has run out OR is dry in print head, go into Printer software and locate "printhead clean".
If print head is not moving maybe fault internally.
Mar 23, 2010 | HP LaserJet 1015 Printer
My Canon Pixma MP610 printer will not print. It
Possible causes: Empty cartridges or new cartridges with cover strip still on the contacts, plugged printhead, wipe with warm water on paper towel to see if all colors are there, also physicallyclean the black cartridge. Try to print. If not working, use the printhead clean and or prime in the printer's maintenance tab.
Mar 09, 2010 | Office Equipment & Supplies
PUT IN NEW INK CARTRIDGES BUT COPIES STILL BLANK AND PRINTING EVEN CHANGING ALL SETTINGS
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Nov 16, 2009 | Kodak ESP 5 Printer
Canon BJC 4400 won't put ink on the paper
You need a new printhead, BC-21E, they wear out and plug with ink and the only repair is to replace the printhead.
Sep 16, 2009 | Canon BJC 4400 InkJet Printer
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
Printing blanks
If you still have the old printer a couple of suggestions that may resolve the issue and provide you with a backup.
Printhead cleaning (manual approach)
  1. Get the printhead off the parking pads and pull the power cord
  2. move the printhead out of the way to the left
  3. soak the parking pad with a distilled water or if possible a mildly ammoniated cleaning solution (the original windex is prefect for this)
  4. move the printhead back into the parking position
  5. leave for 24 hours to allow the solution to wick up into the printhead nozzles and breakdown the clogs.
  6. Plug the printer back in turn back on.
  7. Allow to do a single cleaning routine then print a nozzle check.
  8. You should now get most of your nozzles back.
  9. Allow the printer to reset for another hour and then print off a few test prints..
  10. Repeat if necessary.
This approach is much more effective than trying to use the cleaning routines which rely on the printhead nozzles only being mildly clogged.
If after all that you're still having problems, there's a thriving market for spares/repair printers so it's always worth seeing if you can flog it on ebay or similar, even if it's just for a few pounds/dollars.
Hope this helps for future reference.
Martin
May 23, 2009 | Epson Stylus CX4200 All-In-One InkJet...
EPSON TM U200 POS PRINTER
try a self test print(hold feed and power up) if the printer still does not print check the ribbon to make sure it is inserted correctly. If it is still does not print it could be the printhead or pressure setting. you could also try printing with carbon paper to see if the pins in the printhead are striking the paper.
if the printer is still not marking the paper you may need to replace the printhead or printhead cable.
Oct 17, 2007 | Epson TM U200 Matrix Printer
Canon i9900 InkJet Photo Printer Logo
69 people viewed this question
old marine
old marine
