Question about Atari Imperium Galactica for Windows
How can I run Imperium Galactica on windows 7. Is Dosbox the best or can I use the virtual windows to emulate windows xp
1. How to install and run turbo C++ 4.5 on Windows 7 (32)? 2. How to run Turbo C++ 3 on Windows 7 in full-screen mode?
I had similar issues with an old version of Turbo Pascal.
I used a program called DOSBox which emulates the older machines the packages were designed for.
http://www.dosbox.com/
It worked very well including full screen.
Feb 23, 2011 | Borland Turbo C++ 4.5 Full Version for PC
I have an old print master gold 16 program. Can I some how download it and make it work on my Windows 7 program
you can buy virtual machine program and use older stuff with windows 7. it will require u to install that os also to run it. please vote
Dec 21, 2010 | Computers & Internet
DEAR SIR I HAVE COMPAUTER HP COMAQ DC 7900 I WORK WITH SOME PROGRAM WORKING IN DOS .. THAN I NEED INSTALL DOS OPERATING SYSYTEM THE COMPUTER DON'T RESPON ... ALSO THE COMPUTER DON'T HAVE LPT I BRING CARD...
the best way to do this is probably use windows and run dosbox for windows. What it does is it emulates DOS and lets you run any program that requires dos. Because your computer doesnt have a LPT port. and nowadays only drivers for dos or newer operating systems come with the card. installing the driver in windows then running dosbox, it will see the LPT port.
you can get it here
http://prdownloads.sourceforge.net/dosbox/DOSBox0.73-win32-installer.exe?download
May 04, 2010 | Computers & Internet
Hi, I bought Lemmings many years ago and could not get it to work on my old computer. I now have a new computer running vista. But I still can't see how to run the software. The copy I have is Lemmings for...
In order to run old DOS games on Vista, you will need to use a DOS emulator. One of the best DOS emulators that you can download and use for free is DOSBox.
Here is the link for online instructions for setting up DOSBox:
http://www.dosbox.com/wiki/Basic_Setup_and_Installation_of_DosBox
Apr 05, 2010 | Psygnosis Lemmings 3D for Windows, DOS
Drakan order of the flame engine crashes when i start a new game. i have windows 7 but im running as admin and in compatability mode for win xp sp2. what else can i try?
You could try installing the DirectX version the game uses. (probably on disk)
You can also try to download this Windows Virtual PC.
Windows Virtual PC emulates Windows XP on your Windows 7 PC, so that you can run older applications that won't run on Windows 7 otherwise.
You will however need a processor capable of virtualisation.
Virtualisation check and download here: http://www.microsoft.com/windows/virtual-pc/download.aspx
After installing Windows XP Mode you will need to install the game again in this XP emulator, but after that it should run fine.
I hope this helps,
Yannick.
Dec 08, 2009 | Activision Drakan: Order of the Flame for...
How do u find the ms dos drive
That's because ms dos isn't supported in windows xp
Check out this site for dosbox, a dos emulator
This program should allow you to run all your old dos games
even has support for windows Vista
Nov 02, 2009 | HP Compaq 6510b Notebook PC
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
How to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
Sep 22, 2009 | Microsoft Windows Vista Ultimate Edition
Dos Games and XP
Go to the following web page:
DOSBox is the best DOS emulator I've seen to date. There are numerous web pages available that outline how to use it with specific games. Just do a Google search for DOSBox and your game and you should be able to find all of the info you need.
Aug 24, 2009 | Video Game Consoles & Games
Running graphics c++ programs in TC++
TC++ is 16-bits and 16-bits programs are not fully Windows 2000/XP/Vista/7 compatible. Windows emulates the older 16-bits environment using "NVTDM", but direct hardware access is (by design) still not possible (which is - besides unhandled program exceptions - the main cause for such error messages).
The only - structural - solution is to get a more modern 32 bits C++ compiler instead of TC++. You can find a list of free 32 bits Windows compilers here: http://www.thefreecountry.com/compilers/cpp.shtml
You might have to adapt the existing C++ code a little to the new compiler you choose.
When you really want to continue using TC++ you could use try the free "DOSBox" emulator (which has pretty accurate DOS emulating,. much better than Windows itself) or create a virtual machine with DOS or Windows 3.11 ...
Aug 24, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Atari Imperium Galactica for Windows Logo
485 people viewed this question
Top Atari Video Game Consoles & Games Experts
Hanzu
Reggie brown
param99
Level 1 Expert
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
