Question about Linksys Wireless-G WRT54G Router
Ineed a key to set up a computer to connect to my linksys wireless router
  • 2,260 Answers
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on Aug 29, 2010
Have the key but still can't connect to network
The encryption key maybe incorrect. I suggest you RESET the Linksys wireless router and then configure it again.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 11, 2013 | Linksys WRT160N Wireless Router
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
Hallo! my computer do not accept the router. I set up many times but nothing is working with Wlan. in otherside, the internet ist working via broadband - Linksys(INTERNET) - Linksys(port 1) - Computer. It...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 09, 2011 | Linksys Wireless-G WRT54G Router
How can i get the wpa key from my router
The WPA key is in the router's wireless settings.
http://192.168.1.1
You can protect your router by changing the default PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Apply these settings to the wireless card in your laptop/computer.
Connect your DSL or cable modem to the D-Link router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 13, 2011 | Cisco Linksys E1000 WirelessN Broadband...
What is a WEP key for a Linksys WRT400N wireless router?
The WEP encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
I recommend you use WPA or WPA2 encryption, it is much stronger than WEP.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Linksys WRT400N Router
Find security code for linksys wireless router to connect laptop.
Are you looking for the wireless network key or password ?
If not then you will need to connect the computer to the router.
You will find the wireless network key or password on the set up page of the router.
Click Here
for step by step instructions
Jul 02, 2010 | Linksys WRT160N Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
Lost installation cd cant connect to wireless router wrt54g v8 linksys router need to know how to get it connected to my laptop
If you configure the Linksys wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings it will secure the Linksys wireless router and allow your computer to connect to the Linksys. Please click on this link and follow my instructions to secure your wireless router :-
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
I Can't figure out my wep key I threw Out the box
Click Here for step by step Instructions on how to find the network key
Dec 01, 2009 | Linksys Wireless-G Broadband Router
Ineed to access the router to lock it
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address. (http://192.168.1.1)
3. Enter the router setup, login and password (default Login = admin
and default PW = admin unless you have already changes it)
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 26, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
15 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
