Question about Craftsman 10" Table Saw
How do I adjust the blade so that is parallel to the miter slot on my 10" table saw that is about 10 years old?
  • 2,176 Answers
I fond some model numbers for table saws and I would recommend going to managemyhome.com with your model number and you can download a manual for this tool with detailed instructions on how to align so it is cutting square. I used the model number 11329884 just to see and I was looking at page 55
Posted on Aug 30, 2010
How do I make adjustments on my ridged r4512 table saw?
The carriage under the table is held to the underside of the table with several bolts or screws. Loosen those screws.
Raise the blade and clamp a stiff metal straight edge to the side of the blade. Use a carbide blade and clamp the straight edge to the sides of the teeth. Move the carriage around until the straight edge is parallel with the miter gauge slots, then tighten the bolts.
Oct 12, 2014 | Ridgid Saws
Centering saw blade
The most important thing is that the blade and riving knife are centered with each other. If not, you may have to shim the riving knife.
The bolts that hold the carriage under the table are intentionally sloppy so that you can loosen them and align the blade/knife with the miter gauge slots.
Lay a long metal straight edge against the side of a carbide blade teeth with the blade all the way up, and make sure the straight edge is parallel with the miter gauge slots in the table. Then tighten the bolts on the underside.
Sep 07, 2014 | Craftsman Contractor Series 10" Table Saw...
Blade is not parallel to the channel. How do I adjust it?
Instruction manual for your saw is here. See Page 21. You need to adjust your blade alignment to the miter slots. As mentioned in the manual, there are a couple bolts that hold the rear trunnion in place. Loosen them up, shift the motor a bit (not an easy task). Keep checking blade alignment until you've got it down.
There are after market trunnion alignment kits for table saws that make this a bit easier. Check out PALS (Precision Alignment & Locking System). For $20 or so, it makes the process MUCH MUCH easier.
If this post was useful, please vote. Thanks!
Mar 28, 2010 | Delta Machinery 10" Left Tilt Contractor'S...
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
The saw blade is 1/16" out of parallel with the miter groove in the table. How do I adjust the blade/motor? Thanks
To be that far out of alignment, there must be something loose. Unplug it, turn it over and look for what it is. If you have a drop-indicator gage, and you can clamp it to your sliding miter gage, it will help you get the alignment dead-on. Slide the miter gage toward the front and back in the slot with the tip of the indicator in contact with the blade. Have the the blade at fully elevated postion. If you don't have such a gage, you can clamp a piece of wood to the miter gage to get pretty close. You will probably have to do this with the saw laying on it's backside so that the top and the bottom are accessible at the same time.
Here's the owner's manual
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_OM.pdf
Here's the parts list with an exploded view
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_Breakdown.pdf
Jan 15, 2010 | Hitachi C10RA3 Electric Table Saws
New Dewalt 745 saw, blade not parallel with Miter slot
Either take it back, or take it apart and make the holes bigger. For that kind of money, you should be able to adjust it dead-on. I thought I had the same problem on an old Craftsman, but I found that I just hadn't loosened things up enough. It's hard to see how much wiggle room you really have under the washers. And if there are aluminum castings involved, there can be a burr raised by the initial setting that it gets stuck on.
Dec 28, 2009 | Dewalt DW745 10" Compact Job Site Table...
Adjusting Blade/Miter Groove Alignment on 1950's Craftsman Table
Try using a 1/16 thick flat washer as a shim where the mounting bolts/trunions mate with table. 1/16 shim on front mounting bolt will shift front of blade over 1/16 or 1 on the back mounting bolt will shift back of blade over
Oct 28, 2009 | Craftsman 10" Table Saw
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
How do i square my blade to thmiter slot? it is out by a sixteenth of an inch. it is a 10" table saw, cable driven and the model # is 113-241680
First, check to make sure the blade itself is a flat plane, by measuring the distance from a fixed point to various teeth as the blade rotates. (Usually a magnetic base dial caliper is used to do this.)
Once you know the blade is flat and true, you can use it to set up the saw...
This is a tricky process and requires a bit of finesse. You need to just loosen the bolts that hold the table top to the workings of the saw beneath, and shift the saw relative to the miter slot so the blade is perfectly parallel. You'll probably have to crank it over to 45% to get to the bolts, then crank it back to check the adjustment, so make sure it changes angles easily first, by squirting some oil in there.
When it get it adjusted correctly, tighten the bolts, and check the working of the raise/lower and angle adjustments. You will probably have to reset the stops as well.
I don't see a manual for your saw here, but you might have a look at the other manuals that are there. There may be a saw close enough to yours for the manual to be of some use. See this one, for an example of typical instructions related to your adjustment. (You click on the publication to open it.)
Good luck. It's a bit of work, but worth it. It will make the miter slot functional, and make adjusting the fence a whole lot more accurate.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 06, 2009 | Craftsman 10" Table Saw
Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Jun 01, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Craftsman 10" Table Saw Logo
175 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
