Question about Leupold Optics
Power ring selector on 3-9x Leupold scope is difficult to turn--its stuck!
    President:
  • 2,702 Answers
Inside the scope are runner rings to keep out dust and water the this ring need changing or lubing,,,have the scope serviced dont try to fix it yourself you wll only bust your scope
Posted on Aug 30, 2010
2.5x8 variable leupold loses focus when change power
The only reason a variable power Leupold scope should lose focus when changing power is that the object you are viewing is too close to view on a high magnification. Try again while viewing something 50 yards/meters away, and if it still loses focus, then it probably needs repair.
Leupold scopes aren't user-servicable, and you wouldn't want to try to take it apart yourself, but that's okay, because Leupold has one of the best reputations among optics manufacturers for standing behind their products. If there's a problem, you can call their customer service department at 1-800-538-7653, or submit a request on their online form here:
http://www.leupold.com/corporate/contact-us/service-support/
Either way, don't give up on it. Leupolds hold their value, and you could probably even sell a problem scope to someone who is willing to send it in for repair.
Dec 19, 2010 | Optics
The adjustment 3 thru 9 is too tight and hard to turn. How or who can repair?
This is not uncommon with Leupold scopes. The first thing to try is to get a good grip on the adjustment ring and just crank away, making sure you're not trying to go past the adjustment range marks on the adj. ring. If the ring has not been moved recently(like within the past few months) it can take a surprisingly large amount of arm-strong to break the ring loose. The reason the ring can be so difficult to move is because Leupold uses a close(tight) fit to keep moisture out and the dry inert gas(argon or nitrogen) in. I haven't felt a Leupold yet that didn't require substantial effort to move either the power or occular ring. Be sure to wipe down the exterior of the ring to remove any oil or dirt to insure you obtain maximum adhesion between your hands(you did wash them, didn't you?) and the ring. 70% isopropyl/rubbing alcohol and a paper towel(don't soak it) makes quick work of cleaning the adjustment ring. In any event, DO NOT APPLY ANY OIL/LUBRICANT IN AN ATTEMPT TO TRY TO MAKE THE RING MOVE EASIER! All that will do is probably cause the o-ring seals to begin deteriorating, and then you WILL have to send the scope in for repair. Once you have the ring moving, just work it back and forth until it it moves about as easily as it's going to get. If this doesn't work, get on the horn(telephone,email,etc) to Leupold and they'll likely instruct you try what I told you before sending the scope to them. They normally don't consider this stiffness to be a problem as they consider this to be a sign that the seals are working the way they should. Last time I talked to them nonwarranty problems cost $10, warranty stuff was free of charge. Leupold is a class act; they back their product to the hilt. Good luck!
Nov 29, 2010 | Leupold 3 9 x 50mm VXII Series Riflescope...
Cant adjust windage to the left eneough
There are several potential problems that could be causing this. The most likely are:
misaligned rings
misaligned ring bases
misaligned ring base screw holes
Bent scope
other potential issues
bad scope
bent barrel
poor action bedding (putting enough pressure on the barrel that it throws the bullet to the right, unlikely)
The first 4 are most likely and can be checked by using a different scope. If you have the same issue with the new scope, then look to the rings and mounts as your probable issue.
Sep 04, 2010 | Leupold 66405 Vx3 Rifle Scope 4514x40mm Lr...
Leopold VX11 power adjustment really hard to turn
Take the eyepiece off and clean out the threads with wd-40 or something like that, put on some fresh, light weight oil, a little, and see if it doesn't spin a little better. Sometimes the oil gets gummy and sticky. Hope this helps.
Apr 09, 2010 | Leupold 3 - 9 x 40mm VX-II Series...
Screw missing in ring that adjust varible power - this screw is a knob that sticks up so you can turn it. i need to find this screw
Here's the info I found on Redfield's website:
Warranty InformationWhen Leupold purchased Redfield in April, 2008, Leupold did not assume the Redfield warranty. Because many Redfield customers have contacted Leupold with regard to the former Redfield warranty, Leupold is making this information available to Redfield optics owners.
At this time, three Redfield repair facilities are available should your Redfield product require service: Parson's Scope Service(513-867-0820), ABO USA Inc (305-859-2010) and Iron Sight Inc. (918-445-2001). The contacts provided are for information purposes only, as these companies are not affiliated with Leupold & Stevens. Please contact them for all information regarding repair, service, and associated charges.
As a courtesy we are now offering 20% off the price of a new Leupold scope, up to $100, in trade for any defective Redfield scope. If you would like to take us up on that offer you may call us at 1-800-LEUPOLD.
Jan 02, 2010 | Redfield Optics
I have a Leupold 3x9 VX II I'm finding that both windage and elevation adjustment screws are very difficult to turn. Is there a special tool I should be using for this or should I just be careful with a...
Leupold has a very good service policy, They'll repair it no matter what.
Send it in to them and let the experts fix it.
Here's their contact info:
1-800-LEUPOLD
Hope this helps, Mark the Gunsmith
Dec 06, 2009 | Optics
How does the front base turn on leupold std remington 541
Are you trying to get the front ring to attach to the front base? If so... clamp the ring onto a 1"dia. x ~12" long wooden dowel. Set the ring into the base from the side of the weapon (90^ from the barrel). Making sure the ring is fully seated onto the base, turn the ring/dowel 90^ until the dowel is parallel with the barrel. The fit is quite tight between ring and base. Do not put the ring on and take it back off again as the fit will deteriorate.
* IMPORTANT * Make absolutely certain both the front and rear rings are exactly in line with each other before mounting the scope. You do not want to bend or kink the scope. There are tools you can buy, or... use a 1" dowel in each ring. Align the ends of the rods with slight turning adjustments to the front ring to get both rings pointing the same direction. The rear ring does not turn, only the front one.
Aug 11, 2009 | Leupold Standard 2pc 2-piece Rifle Scope...
Overtighten causes hazing,and adjusment problem
As a general rule of thumb, If you have normal Weaver-type aluminum rings, you tighten to 10 to 15 inch-pounds. If you have normal Weaver-type steel scope rings, you tighten to 15 to 20 inch-pounds. If it's something exotic and/or expensive, you're pretty much stuck contacting the manufacturer. Leupold Mark 4's require 65 in-lb, for instance.
Wiha makes two adjustable torque screwdrivers (one for lower torque, and one for up to 60 in-lb that are perfect for most any scope ring applications.
May 04, 2009 | Leupold ® Rifleman® 3-9x50 mm Scope
Optics Logo
574 people viewed this question
Top Leupold Optics Experts
George Merkley
George Merkley
ray gallant
Are you a Leupold Optic Expert? Answer questions, earn points and help others
