Question about Visonik VB212PKG Car Audio Amplifier
Specificationes the amp visonik vb212pkg - Visonik VB212PKG Car Audio Amplifier
I have good power and ground connections but the amp will not turn on.
Make sure the fuses aren't blown. There should be fuses on the amp itself and an in-line fuse in the live power wire near the car battery. If the fuses aren't blown, make sure the remote wire is connected from the head unit. Then re-check your power and ground connections. The ground should be solidly connected to the vehicle chassis in a paint-free location.
Feb 23, 2011 | Visonik VB212PKG Car Audio Amplifier
How do i hook up my amp. the ground wire and the v 12
well, basically... the 12v (+) power wire is fused and hooked to the battery and ran to the amplifier, then run an amp turn on wire from you radio its usually blue with a white stripe (if you have an after market radio) then run the rcas from the radio to the amp and finally tap the ground (usually and cleaned bare-metal on your car close to the amp).... if you give me some more info i can help u further... what is the make/model/yr of your car, what radio do you have, amp, sub, speakers, etc....?
May 02, 2010 | Visonik VB212PKG Car Audio Amplifier
Amp wont turn on..Visonik vb212pkw
Well you have a high impedance path to your amp. If you have an inline fuse that should have blown. Car batteries don't have a current limiting feature HA The only explanation would be that the amount of current passing through the wire is causing a large voltage drop due to a large impedance. What gauge wire are you using? Here is an example.
18 ft of 8 gauge wire would have to be passing about 400 Amps of DC current to yield a voltage drop of that magnitude. The wire would melt and all hell would break loose. So there has to be a break in your wire somewhere.
Dec 18, 2009 | Visonik VB212PKG Car Audio Amplifier
Installation Guide for Car Subwoofers
MOST OF THE TIME AMPLIFIED BOXES ARE EASYER THAN REG AMPS, ALL U HAVE TO DO IS RUN UR RCAS FROM THE BACK OF UR HEAD UNIT TO THE AMP, THAN UR POWER LEAD, FROM UR BATTERY TO THE AMP, THEN UR GROUND MOSTLY ON THE FRAM OF THE CAR OR ON THE BRACKETS ON UR SEATS, THATS MAINLY ALL U NEED TO NO.
Jun 18, 2009 | Pyramid - PS46KX 35 Amp Power Supply Car...
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Broken Potentiometer
If all else fails and you cannot find the correct pot for it then you might try using two resistors for each "layer" of the pot (there are probably two sections)that add up to 2K ohm and solder them in as a permenant setting to replace the pot. Maybe choose a value like 1.5K for one resister and .5K for the other. This would set your volumn to about three quarters of full. It's not necesarily a good solution, but it will get your amp going again. P.S. It may be a 2.5 K pot with two sections. Good luck.
Apr 11, 2007 | Visonik VB212PKG Car Audio Amplifier
Contact the manufacturer in the owners manual or from where you purchased the unit from, ask them where or who the manufacturer is. Good Luck
Mar 28, 2007 | Visonik VB212PKG Car Audio Amplifier
NEW AMPLIFIER WILL NOT LIGHT UP OR POWER UP
It sounds like your saying that you have two identical amp, that both are on the same power wires and remote wires and sam grounds? Well if thats the case then you did ok as One amp sounds like its blown. First tghing is check the main fuse. If its good and the unit still dosent resond then the power supply in the amp is blown as theres a switching supply that increases the 12 volts to get power to drive the Mosfet output devices. Was it ever working?? yes then the amp needs service. Do you know how to work on solid state elctronics down to componet level?? No?? Ok contact these folks at the addy im posting for you or take the amp to your local servicer. Good Luck. AudioSupport@VisonikCarAudio.com
May 07, 2006 | Visonik VB212PKG Car Audio Amplifier
Car Audio & Video Logo
59 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
