Question about RCA HD52W59 HDTV Projection Television
Turn on tv and it says formatiing hdd failed - RCA HD52W59 HDTV Projection Television
  • RCA Master
  • 8,617 Answers
The small signal board is the usual cause of that problem.
Posted on Aug 29, 2010
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
I have an xbox 360 hdd 120gb its working but i only have a picture but no sound. i have checked the settings, has anyone had the same problem?
Sound is turned all the way up in the setting and the TV? Still cant hear it? Try a different cable if all else fails.
Oct 28, 2012 | Microsoft XBOX 360 120 Gig Hard Drive -...
HDD Recovery failed
I have had this problem intermittently for some time and have not found a solid solution for it yet. The HDD may be going bad or it may be a power supply or digital board problem. I just replaced the 3 bad capacitors on my power supply a few months ago, then the set started having HDD problems. As of now when I want to record, I have to unplug the AC power for a few seconds to get the relays to reset, then the HDD will start and be readable until the next power cycle. Sometimes I have to leave the unit unplugged until the power light goes out completely (capacitors drain) in order to get it to work. I'm still working on a final solution for this issue, but the set is a 2-man lift and a pain to open up.
Last time I had it apart, I noticed that the SATA cable to the HDD was strained where it came off the connector on the digital board since LG used a straight cable instead of a right-angle one. I just ordered a new cable and will let you know how it goes. I also wast to put in a larger disk at some point.
Jan 24, 2010 | LG 42LB1DRA 42 in. LCD Television
I have a Luxor 250gb Digital TV Recorder, was watching it today and it froze, so i tried to re-boot it by turning it off at mains for a few minutes, when i turned it back on it came up saying 'fail' i...
I have recently had the same problem. Unit goes to FAIL on switch on. I've only had it for 18-20 months. I brought it from Tesco and they gave me £40 as a goodwill gesture, so I took the lid off and checked all cables, but it is still faulty. My guess is that the Harddrive (HDD) has failed, as I can't reformat the unit. I will take it to work on Monday and see if I can check out the HDD on a PC....
Jun 21, 2009 | Televison & Video
The hdd has failed on my acer rc500 pc.
You can get the drivers from this link: http://drivers.softpedia.com/get/TV-Tuner-Co/Others/Acer-Aspire-RC500-RC900-TV-Tuner-Driver-5131243.shtml. Or chose your OS if required and then download it....................sodeep
Apr 30, 2009 | Acer Aspire RC500 PC Desktop
Solaris 9 SPARC doesn't work with Maxoptix T4-2600 disks
You must using solaris format utility to label thies T4-2600 drive. And you must put 512byte/sector MO disk into drive. for example:
1.$ su - root ;Become root user
2. # format ; identified disk
3. choose disk
4. label disk
5. if type unknow please input : type
6. choose T4-2600
7. label
8. modify disk partition
9. newfs ; ex: newfs /dev/dsk/c1t0d0s0
10. mount disk
11. using MO disk like HDD
Mar 26, 2009 | Computers & Internet
Can't boot bios
FORMATIE LA COMPUTADORA Y EL CD DE LOS DRIVERS NO FUNCIONA Y NO HE PODIDO CONFIGURAR LA TARJETA DE AUDIO NI DE SONIDO, LOS NECESITO. GRATIS.
P4V533-MX
ieds7113@hotmail.com
Sep 16, 2008 | ASUS P4S533 Motherboard
Turn the xbox on and where the light is green there is only one red light and it says on the screen system error
An original Xbox? On the error screen there should be a number. Which is it?
2 - bootldr - Eeprom check failed
4 - bootldr - Ram check failed
5 - kernel - HDD not locked
6 - kernel - Cannot unlock HDD
7 - kernel - HDD timeout
8 - kernel - No HDD found
9 - kernel - HDD parameters (
10 - kernel - DVD timeout
Actually its almost the same as error 6/7/8.
11 - kernel - No DVD Found
12 - kernel - DVD parameters (PIO/DMA)
13 - kernel - Dashboard launch fail
14 - dashboard - Error loading dashboard
16 - dashboard - Clock cannot be set.
20 - kernel - The dashboard was attempted to load and failed
21 - anywhere -
Some of these are relatively simple to fix. Some are nightmarish. Let me know which it is and maybe I can help you.
Jul 10, 2008 | Video Game Consoles & Games
Sony Nw-hd5 mp3 player, format dive?
I HAVE A NW-HD5.I AM FORMAT MY NW-HD5 BY COMPUTAR.THEN DO NOT PLAYING ANY SONG AND REMOVE ALL FOLDER.SO HOW CAN I IT
Oct 17, 2007 | Sony NW-HD5 MP3 Player
LGRH177
it should be the internal HDD failure...befause the player fails to checking the HDD during starting up ...
good luck !
Aug 25, 2007 | LG RH177 DVD Recorder/HDD Recorder
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
