Question about Kaz Dehumidifiers
My dehumidifer start and stop often when the humidity reaches it`s set point.????
  • Kaz Master
  • 43,501 Answers
the humidistat or sensor has gone bad...
heatman101
Posted on Aug 29, 2010
Model hd456e- when the desired humidity is reached will the dehumidifier stop running?
It should. If not it is defective or undersized for the application.
Start it out at high (moist) setting - it should go off soon. You can then move it slowly to drier settings and see that it runs longer before stopping. Stop when you get to a comfortable setting.
Sep 22, 2017 | Dehumidifiers
Should the fan shut off when the humidity setting has been reached for model Frigidaire CAD504DWL 50-Pint Two Speed?
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
Sep 12, 2014 | Dehumidifiers
Why has it stopped running, but still shows temp and humidity?
I may have reached the humidity level that you have set it at. Press the HUMIDITY button until it says "Lo". That should put you into continuous run mode.
Good Luck.
Jun 09, 2014 | Haier DE65EJ Dehumidifier
Humidity sensor
It may be right. Are you sure you need dehumidification?
Put a free-standing humidity meter near the unit to check.
If you still want to run the dehum, take the humidity sensor out of the line and control the unit with a timer.
Aug 17, 2017 | Maytag M7DH45B2A Dehumidifier
I purchased a 65 pint LG dehumidifer # LG LHD65EBL. This is the second one that I have had. I had to return the first one because it would not shut off when bucket was full. This one runs for about a...
First, tunr the unit OFF and unplug it for 10 minutes. Then plug it back in and turn it ON. It will automatically set at 70%. Press the - button and lower the humidity extraction level to 45% in increments of 5%. Once you reach 35% press and the - button one more time. Now the unit is set to run continuously, until the bucket is full and the unit turns OFF automatically or you manually turn the unit OFF. In case you have misplaced the Owner's Manual, I have included a link to it, that you can download and print. http://aic.lgservice.com/gcsc/dwn/main
I hope this helped you and thanks for choosing FixYa..
Jul 29, 2011 | LG LHD65EBL Dehumidifier
I was just given a DD50PC as a gift from a friend who did not have the accompanying instruction booklet. He told me to turn the unit on and let it work. I do not know what temp to set it at. It has to...
On a dehumidifer, you set the relative humidity, not temperature. Normally the humidity should be set within 40 to 60 percent humidity.
Click on this link for a copy of the manual for your machine. www.sylvane.com/images/.../delonghi-dd50p-dehumidifier-user-manual.pdf
Hope this helps you.
Jul 01, 2011 | DeLonghi DD50P Dehumidifier
When the humidity set point is reached, the compressor shuts off but the fan continues to run. Is this normal?
Chucke - Depending on which mode you're operating the unit in (Continual Mode), yes that is normal.The fan continues to run in an effort to recirculate the air. If it senses a rise in humidity above the level you have it set on, the compressor will turn and remove that humidity.
Hope this helped you.
Jun 27, 2011 | Frigidaire Dehumidifiers
The dehumidifer stopped collection of water
What is the proper setting. My unit saids On and 35 to70 Humidity according to the unit is 65 This is a LG.
Jun 15, 2010 | LG LHD45EL Dehumidifier
Runs, but no dehumidification. 6 months old.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Haier Dehumidifiers
Dehumidifier won't shut off
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
Dec 29, 2008 | LG DH30 GoldStar Dehumidifier
Dehumidifiers Logo
100 people viewed this question
Top Kaz Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Kaz Dehumidifier Expert? Answer questions, earn points and help others
