Question about Whirlpool Washing Machines
My front load washer is throwing an error code f-02.what does that mean?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
Long spin cycle of my Samsung WF8590NHM Front Load Washer is always interrupted and throws this flashing "5d" error code.
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
Aug 20, 2011 | Samsung WF306BHW High Efficiency Front...
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Keeps throwing an F2 code
Hi
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02washer dryer problem
F02 means the motor is stuck or jammed, check the motor , tacho and module. For more Hotpoint, Creda and Indesit error codes use this link
Mar 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Dec 25, 2008 | Kenmore Elite 45986 Front Load Washer
F02 code
F 02 means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed. Potential Causes
• If the above does not correct the problem replace the pump
Jan 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
