Question about LG Televison & Video
My lg bd 390 does not want to load everytime you power up the unit it keeps giving " please Wait " and nothing else is happening. I tried to uplug for some time and trun it up again but it is doing the same. I just bought the unit a week ago and turn it on for the first time and it was working fine and i updated the firmware through the internet. I turn it of and when I came back in the end of the day , it didn`t want to work any more as I described before. LG in my country refused to help because the unit was bought from outside the country. WHAT SHOULD I DO ??????
  • 10,594 Answers
Only option is to update firmware again by hooking it to internet as previous update got some problem in downloading update files and causing problem.
Update its firmware again to solve the issue or return the unit for warranty cover if it is possible.
Thanks.
Posted on Aug 28, 2010
The unit will not turn on after trying the pushing the power button. The green light on the reset button shows that it is on but on the display not lights are on. I tried to inplug and wait and plug the...
You need to bypass the on/off switch by jumping it, thereby taking the switch out of the circuit. If it works you have a bad switch. If it doesn't you have a power to the switch problem. Do you have a multimeter and a wiring diagram for this unit?
Aug 02, 2011 | LG Heating & Cooling
I have the "please wait"
The problem is associated with the Laser / Drive Mechanism.
I take it they told you to :-
1) Unplug and leave for a few minutes.
2) With the On/Off Button Pressed, Plug in and wait for the unit to reset.
If you've done this and still get the same fault then it requires further investigation by an engineer but not necessarily an LG one.
Apr 24, 2011 | LG LHB535 Theater System
I have windows xp media center edition 2005 and i have downloaded a driver for my new monitor lg E2250 and my computer have shut down.. since that i cant load windows i cant boot in safe mode for a...
Try to connect another monitor. It may be that your operating system do not properly recognize the monitor, and it was fixed in the protection because a resolution or refresh rate too high.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 12, 2011 | Computers & Internet
Hi there , I am trying to watch Planet Earth blue ray disc on lg bd 390 and for some reason any of the discs does not load (there is 6 of them).i thought it was a bad product and I asked for an exchange...
Try disabling BD-Live.
On the LG BD390 go to the Home screen then select the following:
Settings-->Network-->BD-Live Connection
You have three options: Permitted, Partially Permitted (default), and Prohibited.
Change the setting to Prohibited.
Now reload the disk and try again.
If that doesn't work try clearing the BD Storage (memory about the disks you play).
Again from the Home screen:
Settings-->Others-->BD Storage Clear
I think changing the BD-Live setting will stop the problem you're experiencing. If that works, you could also try changing the setting to Permitted.
I am experiencing issues with some of the very latest Blu-Ray disks, such as Avatar and Date Night. I don't have enough experience to be sure yet, but so far the evidence points to a new setting or standard in the disk industry that does not play well with the Partially Permitted default setting on the LG BD390 and a few other Blu-Ray players.
I hope this helps. Good luck.
May 22, 2010 | LG BD390 Blu-Ray Player
How to unlock code to make my LG BD-390 region
The fix doesn't work once you have updated the firmware.
If you did the update, you can still go back to the firmware of Aug 2009
(http://www.lge.com/us/support/product/support-product-profile.jsp?customerModelCode=BD390&initialTab=documents&targetPage=support-product-profile).
Once you have installed the past firmware, you can install the hack. Choose region 0 and save.
Then you can update again the firmware to the last release and the multiregion will still work.
Good luck
Sep 03, 2009 | Sharp DVRW250 DVD Players
My LG RH278 just says Please Wait when I start it but nothing happens.
Had same problem on sameLG unit. Found a Sony blog with same issue described and solution was a blown capacitor on the power supply circuit. Opened my unit and sure enough there was a bulging cap. Replaced it and starts up like normal. 90c repair. 53c88b9.jpg6643815.jpg
Apr 23, 2009 | Televison & Video
Pioneer BDP-f1FD Disc Tray Won't open
I fixed this on my unit from a tip on AVS Forum
Unit has "Power on" msg, follow these steps:
1) Hit power button for 5 -10 sec unitl unit shuts off
2) Press open / close button unit or remote first (do not hit power button first)
3) On the third try, the disc tray opened
I had James Bond Goldfinger in the player ( not sure if this had anything to do with it), I put another Blu Ray in and it loaded fine and is playing fine, hope this works for you
Dave
AVS link below
http://www.avsforum.com/avs-vb/showthread.php?t=1054927&page=413
Apr 20, 2009 | Pioneer BDP-51FD Blu-Ray Player
LC32SH20U Please wait screen
I have had many problems with these unit with internal cables being loose or not seated properly. This is most likely the case, or the unit has a bad main. BD. If is new you can probably exchange the unit where you bought it, or contact Sharp and they will set you up with an auth. service center to correct the problem.
Jan 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Computer Repairing
Computer Repairing
